Posted: Mon Dec 11, 2017 9:33 am Post subject: intel moble i7 ES development board |
Hi
I got a very interesting intel moble i7 ES development board.
The CPU is ES (QDX1 ES), south/north bridge is ES. There are lots of interfaces and switches on board.
I can not boot it up correctly.
It ended up the LED blinking with "1 0 C 3? code? The screen display nothing, even I connect two screen with VGA and HDMI.
Please help me.
There are many photos, please view here:
https://pan.baidu.com/s/1eRIFRea#list/path=%2FES_board&vmode=grid _________________ My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum |
Posted: Mon Dec 11, 2017 10:52 am Post subject: |
It's a Core i5-4570R with 128 MB L4. This board was used to demonstrate the Crystal Well platform. It's a QS (ES have SMA connector soldered). Both CPU and chipset are probably unsoldered BGA. Extremely fragile. If you remove the BGA support, there is almost no way to put it back on correctly. _________________ ES-Only Collector : http://www.engineering-sample.com
Universal Chip Analyzer (UCA) : https://x86.fr/uca / http://www.cpu-world.com/forum/viewtopic.php?t=34349 |
Posted: Mon Dec 11, 2017 11:47 am Post subject: |
| xsecret wrote: | | It's a Core i5-4570R with 128 MB L4. This board was used to demonstrate the Crystal Well platform. It's a QS (ES have SMA connector soldered). Both CPU and chipset are probably unsoldered BGA. Extremely fragile. If you remove the BGA support, there is almost no way to put it back on correctly. |
thanks for your info!
how can I make it work then.... I will try again _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Tue Dec 12, 2017 1:14 am Post subject: |
now I figured out the boot up error code is 01 (EC01)
so it might be CPU self check failure? _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Fri Dec 15, 2017 9:05 am Post subject: |
Now NO error code now, the four bits LED shows "0000", but still no display on the screen... _________________ My vintage CPU collection:www.cpumuseum.com
Posted: Mon Jan 08, 2018 6:04 am Post subject: |
| hugo929 wrote: | | I made it working, very very nice and fast |
Mission Impossible.  |
