Came across some 128GB RAM sticks from INTEL?
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips
theFrugalGourmet
PostPosted: Mon Aug 20, 2018 12:35 pm    Post subject: Came across some 128GB RAM sticks from INTEL? Reply with quote
Hello friends,
I was lucky enough to receive these Engineering Samples as they were getting ready to be decommissioned, but my background knowledge is pretty limited with hardware.
They are quite fascinating since Intel hasn't produced DRAM but they are dated 2017, so most likely these are proprietary hardware. I have some thoughts about what these are but I'd like to hear what you guys can come up with.
https://imgur.com/Py0fEpu
https://imgur.com/6X61kEs
max1024
PostPosted: Mon Aug 20, 2018 12:47 pm    Post subject: Reply with quote
DDR4 Slot.
adamajer
PostPosted: Thu Oct 25, 2018 4:29 am    Post subject: Reply with quote
DDR4 registered memory, most likely manufactured by Micron for Intel. Micron is the one that use Black heatshields on their memory sticks. Size is pretty regular in server world.
Nike486DX
PostPosted: Thu Oct 25, 2018 8:07 am    Post subject: bits or Bytes? Reply with quote
Are you shure that the memory size was denoted in GB and not Gb?
BTW 128Gb = 16 GB. (8 bits = 1 byte)
That may be confusing sometimes, i know, but i've seen quite a lot of server ram modules (primarily some FBDIMM's) that have something like "64Gb", "128Gb" , "256Gb" printed on their labels (8, 16 and 32GB respectively).
adamajer
PostPosted: Fri Oct 26, 2018 3:35 am    Post subject: Reply with quote
FBDimms are DDR2 Fully Buffered memory, and Manufacturers used to have a bad habit of selling them in Kits, marking the kit capacity on the individual memory sticks. This is not the case anymore for DDR3 and DDR4 memory. Only Kingston does it nowadays.
Back to subject, your memory is PC4-2400T registered memory, most likely manufactured by Micron for Intel (Black heatshield is normally used by Micron only in the server memory world).
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips All times are GMT - 5 Hours
