upgrading Inspiron 1545
HHD
PostPosted: Tue Oct 23, 2018 11:47 am    Post subject: upgrading Inspiron 1545 Reply with quote
Hello. I'm glad to find this site and hope to be helpful. Upgrading Dell Inspiron 1545. New RAM, SSD work fine. Replaced CPU T4400 with P9700. Laptop will not start, at all. Power light flashes very quickly, then it is dead. Put T4400 chip back in, all is well. All info I find clearly says P9700 should work, no problem. But it doesn't and I cannot find any obvious reason. Any help here? Thanks very much in advance.
PostPosted: Tue Oct 23, 2018 3:21 pm    Post subject: Reply with quote
Do you have latest bios installed?
Or P9700 it's dead or read the gray text here
http://www.cpu-upgrade.com/mb-Intel_(chipsets)/GM45_Express.html
HHD
PostPosted: Tue Oct 23, 2018 8:37 pm    Post subject: Reply with quote
yes, bios is latest. what do you mean by "grey text"?
PostPosted: Tue Oct 23, 2018 11:07 pm    Post subject: Reply with quote
Quote:
Important: Below is a support list for the GM45 Express chipset, and not a support list for your motherboard, built on that chipset. The chipset is only one of key elements that determine CPU compatibility. Other key factors are: socket type, package type, maximum Thermal Design Power, BIOS version, CPU core name and stepping. For that reason not all motherboards, built on the chipset, will be compatible with all listed processors. Please use the list only as a guidance.
HHD
PostPosted: Wed Oct 24, 2018 12:36 pm    Post subject: upgrading Inspiron 1545 Reply with quote
Thank you, CPUShack. I don't know about any of the items you listed, nor what a "chipset" is. All I know is using google and the internet I found several places (various forums, websites, companies, etc., and the seller itself) that said the computer supported the cpu and vice versa. Nowhere did I find the reverse opinion or any advice about your listed items. T4400, original OEM cpu, 9 years old, works fine before and after replacing with P9700, and computer will not power up with the brand new P9700 installed. Is it most likely a defective cpu, or most likely something else and if so, what would cause it? That's the question I was hoping to get answered here, or somewhere. Thanks again!
crazybubba64
PostPosted: Wed Oct 24, 2018 2:13 pm    Post subject: Reply with quote
ooof disregard the previous content of this reply. I made a mistake with the chipset used.
It could be a faulty processor? Otherwise, have you updated your BIOS? Dell's support page should have a download available.
In my brief time looking, I did not find any of these running with a 'P' processor, so it may be a bios compatibility thing? Maybe look for a 'T' chip like the T9600, etc.
You could also pick up an X9100 for not much more and get a very nice performance bump.
