DAVID BRUNNER Guest
Posted: Mon Feb 18, 2019 12:58 pm Post subject: I don't find the PAE, NX, CMPXCHG16b (CX16), LAHF-SAHF & |
In a Spanish page say that this options are need for Windows 8
Why don't appears in the cpu's info? |
DAVID BRUNNER Guest
Posted: Mon Feb 18, 2019 1:17 pm Post subject: |
| ......& PREFETCHW (not enter in the other post) |
Posted: Mon Feb 18, 2019 1:19 pm Post subject: |
This site has never listed every programming instruction. _________________ My graphics card database can be found at http://www.gpuzoo.com.
DAVID BRUNNER Guest
Posted: Mon Feb 18, 2019 2:29 pm Post subject: |
debs3759 I thought that these name are the same that SSE2 that too appears in this page:
www aboutespanol.com/saber-si-tu-cpu-admite-pae-nx-sse2-para-windows-3507762 |
Posted: Mon Feb 18, 2019 3:00 pm Post subject: |
NX is listed here, but basic instructions aren't.
SSEx is a set of instructions, an extension to the processor instruction set. CMPXCHG16b (CX16), LAHF-SAHF are all single instructions and well established. _________________ My graphics card database can be found at http://www.gpuzoo.com.
agent_x007
Posted: Mon Aug 19, 2019 6:42 am Post subject: |
Coreinfo shows if your CPU support those or not (it's command line utility) : LINK
Also, For Windows 8.1/10 x64 you need a AM2 CPU (K8 revision Fx), OR any Intel 65nm.
No support for S939 or S940 or Smithfield/Prescott(-2M) on LGA 775. |
karman
Posted: Mon Aug 19, 2019 7:57 am Post subject: |
I usually start any linux live and do a:
cat /proc/cpuinfo |
