HighVoltageLP Guest
Posted: Sun Sep 15, 2019 6:32 pm Post subject: Making a socket 775 CPU's display frame |
Hi guys,
So I've decided to build a display case/frame to hang on a wall, similar to those used by coin collectors:
Here's an image from Amazon amazon.co.uk/Black-Display-Quarters-2010-2020-Included/dp/B00NLQNP5C
It will be made of 8mm MDF with milled openings for CPU's and flocked with a black coating, covered with a sheet of glass (or plexi?) and framed.
But now I have a problem, while deciding on the number of openings and size of the frame, I have compiled a few lists of socket 775 CPUs and, even excluding 771 ones, got anywhere between 180 and 200+
I really need help deciding on a final list, I would probably exclude the engineering samples (everything with Intel Confidential on the IHS) and put those into a separate frame so not to make this one too big (180 CPU's divided into 10 rows and 18 columns already comes out at 62*110 cm) |
