How to tell the difference
H3nrik V!
PostPosted: Fri May 29, 2020 4:58 am    Post subject: How to tell the difference Reply with quote
So, I have these 3 .. PII-400, P!!!-533B and P!!!-500.
How would I know, which was what, if I didn't have the housings too?
Thanks,
rjluna2
PostPosted: Fri May 29, 2020 7:27 am    Post subject: Reply with quote
I hate that Mad
But, it would be nice to find minute details from one to another Very Happy
Katmai500
PostPosted: Fri May 29, 2020 9:16 am    Post subject: Reply with quote
The one in the upper right is the PII 400. It has a different PCB layout and a slightly smaller die (7.5M transistor Deschutes vs 9.5M Katmai).
Between the Pentium III's, it's not as easy. They also have different PCB layouts, but that's not conclusive of which is which. There may be a way to figure it out based on some of the SMD components on the PCB, but I'm not sure and a quick google search didn't turn up anything.
I can look through all my Katmai PIII's and check for patterns.
PostPosted: Fri May 29, 2020 9:39 am    Post subject: Reply with quote
Looking at cache speed left is 533, bottom is 500.
In case not having plastic cover test ot to find multiplier and again look to cache speed to distinguish between possible fsb speed.
Katmai500
PostPosted: Fri May 29, 2020 11:36 am    Post subject: Reply with quote
Good point. The 250 MHz cache on the bottom one wouldn't be equipped on the 533 MHz CPU. With later production CPUs isn't it likely that faster cache was used on the slower CPUs? Making this technique good for process of elimination, but not great for identifying a single CPU without plugging it in to check the multiplier?
H3nrik V!
PostPosted: Fri May 29, 2020 3:41 pm    Post subject: Reply with quote
No need to, these are all in their plastics. Was just wondering, if they weren't .. If the would be any markings on the PCB or something, like the Celerons. Also I was surprised to see the close size between deschutes and katmai ..
