Adblock warning but site isn't blocked or adblock enabled
PostPosted: Wed Aug 19, 2020 7:37 am    Post subject: Adblock warning but site isn't blocked or adblock enabled Reply with quote
I had issues with a warning message that adblock is on (in red).
Everything is disabled and it still gives me the warning.
Tried all and non worked.
I use Linux Mint and FF latest version.
PostPosted: Wed Aug 19, 2020 7:49 am    Post subject: Reply with quote
Are you on a corporate network? Maybe they block ads.
Or do you use Pi-hole on your network?
PostPosted: Wed Aug 19, 2020 7:16 pm    Post subject: Reply with quote
Nope, from home.
xedd
PostPosted: Tue Sep 08, 2020 3:05 pm    Post subject: Reply with quote
I've also started to see this recently. Firefox and Chrome on Windows and Linux. Even at work where we can't install add-ons/plugins on browsers. I can only assume it's a DNS thing or ISP thing - it's the only commanility I have in my case.
I use this site a few times a year and occasionally poke around the forums - I'd be more than happy to pay and not have this issue or see adds if it were an option.
svmlegacy
PostPosted: Tue Sep 08, 2020 3:33 pm    Post subject: Reply with quote
I'm running Fedora 32, Firefox 80, no issues here.
PostPosted: Tue Sep 08, 2020 3:38 pm    Post subject: Reply with quote
Members who are in the collectors group are able to browse the website without ads. I think CPUShack is the most active member here with the admin ability to add you, when he reads this. That feature (ie telling you to unblock from your adblocker) is broken, but is intended to stop people from scraping the site. gshv, the site owner, might need to look into it if you are getting messages wrongly.
PostPosted: Tue Sep 08, 2020 4:21 pm    Post subject: Reply with quote
D.8080 is in the collectors group already
PostPosted: Thu Sep 24, 2020 8:59 am    Post subject: Reply with quote
I've been harassing these pages for quite a while.
I still have the issue.
Edit: looks like it works without issues now...
I'll report back if does it again.
I was wondering, could it be that blocking google analytics or google related ads could cause the problem?
Google is everywhere.
PostPosted: Thu Sep 24, 2020 1:31 pm    Post subject: Reply with quote
Solved, the thing is caused by my tracking options in FF being set to "strict".
If set to standard, content loads properly and I don't get the adblock reminder.
PostPosted: Thu Sep 24, 2020 4:42 pm    Post subject: Reply with quote
D.8080 wrote:
Solved, the thing is cause by my tracking options in FF being set to "strict".
Is set to standard content loads properly and I don't get the adblock reminder.
Good to know!
