Intel 486DX-50 T and C
i440bx
PostPosted: Mon Jun 07, 2021 5:30 am    Post subject: Intel 486DX-50 T and C Reply with quote
Hei there,
someone can tell me the difference in this CPUs?
What means "C" and "T"?
Greetings
SX546 SX547
i440BX
My collection: http://www.x86-guide.net/i440bx/en/collection.html
rjluna2
PostPosted: Mon Jun 07, 2021 6:49 am    Post subject: Reply with quote
It would be interested to see if they have different CPUID in between two here Confused
mavroxur
PostPosted: Mon Jun 07, 2021 4:57 pm    Post subject: Reply with quote
Plant code maybe?
i440bx
PostPosted: Mon Jun 07, 2021 5:03 pm    Post subject: Reply with quote
That should be on the backside...
i440BX
PostPosted: Mon Jun 07, 2021 10:14 pm    Post subject: Reply with quote
the DX-50s are very odd chips, they run hot (always made me think the T/C had something to do with thermal/coller requirements.
THey also usually require extra wait states on motherboards to even work, which could also be denoted at least by the T
PostPosted: Mon Jun 07, 2021 10:32 pm    Post subject: Reply with quote
The other choice I had in mind.. is that a lot in their uncleaned state have had OEM stickers.
I am wondering if these OEMs requested additional testing of chips supplied to them & the letters defined compliance to the OEM order requirements
i440bx
PostPosted: Tue Jun 08, 2021 12:58 am    Post subject: Reply with quote
I think its time to test.
If one CPU has extra wait states it should be measurable slower than the other one.
i440BX
PostPosted: Tue Jun 08, 2021 1:19 am    Post subject: Reply with quote
very few cpuids in CPU-world database.. this datasheet is on chipdb.org
http://datasheets.chipdb.org/Intel/x86/486/Intel486.htm
in a few weeks I will download & add markings & other cpuid info from other sources & create a master spreadsheet of 486s
pretty sure Chook has a lot of additional info.. especially timeline info
SX408 is also same cpuid & is marked T. other Ts are SX705 SX710
SX409 unknown stepping? is marked C
H3nrik V!
PostPosted: Tue Jun 08, 2021 1:22 am    Post subject: Reply with quote
Wouldn't the wait states be required by other peripherals etc. on the main board to cope with the 50MHz bus speed?
PostPosted: Wed Jun 09, 2021 10:56 am    Post subject: Reply with quote
486DX-50 is also unique in that according to datasheet it uses more pins that all other i486 (where they are not used) and all corresponding signal names start with T.
i440bx
PostPosted: Wed Jun 09, 2021 10:59 am    Post subject: Reply with quote
Idea
Yes. A look into the datasheet. I should have this idea
i440BX
