List of every CPU ever made
kylejackdaniels
PostPosted: Tue Sep 28, 2021 9:37 am    Post subject: List of every CPU ever made Reply with quote
Hello,
Love the site as comes in very handy at my work! Is there a table list of every possible CPU made?
Like an CSV document that can be filtered with microarchitecture, cores, family, etc.
Kind regards,
Kyle
PostPosted: Tue Sep 28, 2021 9:51 am    Post subject: Reply with quote
I doubt it, as more unknown CPUs are always being found. Best way to find info has always been to browse/search large online collections, such as cpushack.net and sites like chipdb.org
This site has a comprehensive links page with many links to sites with lots of great info not found here
karman
PostPosted: Tue Sep 28, 2021 10:19 am    Post subject: Reply with quote
It would be more reasonably to make a list of architectures (ISA) instead of CPUs.
cuttingedgecs
PostPosted: Tue Sep 28, 2021 10:27 am    Post subject: Reply with quote
I don't think it would even be possible to compile such a list. The CPUs that we know about are the ones that are marketed by their manufacturers for use in products which third parties design. There are so many CPUs, and particularly SoCs which integrate CPUs in their design, which are in-house designs, and are trade secrets of their company, and no one outside the company knows the architecture, cores etc. There have been so many circuits I've looked at in things like phones, GPS, early mobiles, cameras etc where I can see something that looks like it must be a CPU or contain a CPU, but I can't tell what it is from the part number. So it would be impossible to compile a full CPU list when so many are undocumented in the wild.
kylejackdaniels
PostPosted: Tue Sep 28, 2021 10:40 am    Post subject: Reply with quote
What I'm kind of looking for is all Intel (Desktop, Mobile, Embedded, Server) and AMD CPU's and possibly Apple.
Something which i can then turn into a csv list, as working on a program that you can select you CPU from the list.
wren4777
PostPosted: Tue Sep 28, 2021 10:44 am    Post subject: Reply with quote
Not sure if it'll work for your use case, but Wikipedia has a pretty comprehensive list of Intel and AMD CPUs. I'm pretty sure you can download Wikipedia pages for offline use, to plug into your program, or you can create some kind of web scraper.
My WTB List
My collection
Have a nice day! Smile
Borris70
PostPosted: Tue Sep 28, 2021 10:47 am    Post subject: Reply with quote
The last try to create this list was 1998 from Aad Offermann
http://www.faqs.org/faqs/pc-hardware-faq/chiplist/part1/
best regards borris
++ cpu-sammlung.de ++
kylejackdaniels
PostPosted: Tue Sep 28, 2021 10:57 am    Post subject: Reply with quote
Well, If i create a list. Ill post it on here as an online csv!
Thanks anyway people!
kylejackdaniels
PostPosted: Tue Sep 28, 2021 11:09 am    Post subject: Reply with quote
I have this link:
https://www.cpu-world.com/cgi-bin/CPU_Chart.pl
Which can display ever single CPU however it only shows 100 Results at a time. Any idea how to change that?
