shreck16100
Posted: Wed Nov 17, 2021 2:47 pm Post subject: upgrade de puce intel P6100 |
Bonjour
j ai un pc portable asus K72F-TY131V
avec un processeur intel P6100.
je souhaite changer le processeur pour un plus puissant.
quel processeur puis-je mettre à la place ?
merci de votre aide
cordialement |
Wasmachineman_NL
Posted: Wed Nov 17, 2021 4:06 pm Post subject: |
| English, please. |
Wasmachineman_NL
Posted: Wed Nov 17, 2021 4:07 pm Post subject: |
| To actually answer your question though: a i5-5xxM would blow it out of the water. |
svmlegacy
Posted: Wed Nov 17, 2021 4:52 pm Post subject: |
The fastest CPU available is the Core i7-640M.
Any from the Core i3-3xxM, Core i5-4xxM, Core i5-5xxM, or Core i7-6xxM will work. |
Wasmachineman_NL
Posted: Wed Nov 17, 2021 5:38 pm Post subject: |
| svmlegacy wrote: | The fastest CPU available is the Core i7-640M.
Any from the Core i3-3xxM, Core i5-4xxM, Core i5-5xxM, or Core i7-6xxM will work. | And I happen to have a few i5's from that series. |
shreck16100
Posted: Thu Nov 18, 2021 2:14 am Post subject: remerciement |
Bonjour
je vais prendre le I7 640m
un grand merci pour vos Réponse rapide.
cordialement
Hello
I will take the I7 640m
Thank you very much for your quick reply.
Sincerely |
