laptop p4 cpu speed problem!
subject
PostPosted: Fri Mar 24, 2006 11:28 am    Post subject: laptop p4 cpu speed problem! Reply with quote
hi guys, another newbie to this forum, but hope you guys can help.
Right, Ive been making tracks for 4 years now, and eneded up purchasing a 3.6ghz pentium 4 laptop.Its never performed amazingly, and now im running pro tools with an mbox and its getting ridiculous. The CPU gets eaten straiught away, i have no other tasks running, ive done all the obvious tweaks and the music xp tweaks. Paid so much money im getting pissed off.
So, i ran CPU hot check, and it appears the name of mine is a 3.06ghz, but the actual speed is only 1996mhz! Someone help me, its stopping my creative flow!
check this out, its my system general view....notice the 1.60 underneath a 3.06?
http://myspace-231.vo.llnwd.net/00594/13/28/594448231_l.jpg
My power scheme is always on, my buddy has a 2.4ghz and his system is showing 2.04 and then 2.04 beneath it!
Why is my cpu running so much lower thanit should be?
Pentium 4 3.6 ghz (running at 1.9?!what!!?)
512mb ram
60gb hard drive (300gb external usb2)
thanks for your tme guys,
Subject
www.myspace.com/subjectsound
Hot CPU Tester Pro(Lite Edition) 4.2.2
Copyright © 1999-2003 7Byte Computers
Thursday, March 23, 2006 - 22:47:33
Diagnostic Report
Test Started at: 16:17:35
Test Duration: 06:00:01
Physical Processors Available: 1
Logical Processors Available: 1
Multi-Processors System(SMP): Not Available
Hyper-Threading Technology: Not Available
CPU Name String: Genuine Intel(R) CPU 3.06GHz
Speed: 1599MHz
Logical Processors Tested: CPU 0
Average CPU(s) Performance: 100.0%
Modules Results:
Complex Matrix: Finished without error
Calculating Pi: Finished without error
Sorting Algorithms: Finished without error
Prime Test: Finished without error
Fast Fourier Transforms:
Chipset:
L1 Cache:
L2 Cache:
Memory: Finished without error
HD: Finished without error
MMX: Finished without error
Hippo
PostPosted: Fri Mar 24, 2006 1:34 pm    Post subject: Reply with quote
Is it running some sort of speedstep technology, throttling the CPU speed when its doing very little to save on battery power. Try running something like Prime95 to stress the CPU and then check the CPU speed.
CPU-Me! Hippo's Collection Online
PostPosted: Fri Mar 24, 2006 1:53 pm    Post subject: Reply with quote
Just followed a microsoft tutorial to find max clock speed and it says i have a 3.06ghz but the max clock speed is 1599mhz!
THIS IS MAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PLEASE PLEASE HELP!!
Hippo
PostPosted: Fri Mar 24, 2006 1:56 pm    Post subject: Reply with quote
Have you checked what I asked you to check?
PostPosted: Fri Mar 24, 2006 2:17 pm    Post subject: Reply with quote
That will take 10hours. If my max speed is 1.60, and its running at that, is there any point?
Hippo
PostPosted: Fri Mar 24, 2006 2:25 pm    Post subject: Reply with quote
No it wont. Run a prime95 stress test and while its running check your CPU speed. It'll take less than 5 mins. That way you'll know.
PostPosted: Fri Mar 24, 2006 3:28 pm    Post subject: Reply with quote
Lol, your cpu is probably not 3,6GHz...
