cedrik
Posted: Thu Nov 03, 2022 5:29 am Post subject: broken Nexgen |
Sad day for collecting I found a broken NexGen and the corner was missing.. The good part that i also found a chipset NexGen NxVL and it seems to be ok ...
What has been your biggest disappointment since stared to collect CPUs? _________________ https://www.facebook.com/CPUCollectionRO |
crazybubba64
Posted: Thu Nov 03, 2022 10:19 am Post subject: |
I have a few ebay "rescues" that ended up being dead or mostly dead.
AMD Ryzen 9 3950X ES 100-000000033-02 - POSTed once, then never again... Still not sure what allowed it to work that one time.
Pentium 75MHz ES Q0649 (serial number 0001) - Chipped corner, doesn't POST.
Core 2 Extreme QX9770 Q3YN and Q9PM - Don't POST at all... _________________ My collection |
Williac
Posted: Thu Nov 03, 2022 7:42 pm Post subject: |
Tragic, but maybe not a complete loss. Looks like the die might be intact if you want to do a die shot.
I had an old SPARC like that. Was able to successfully delid, and die was intact. Got some nice pictures. |
Posted: Fri Nov 04, 2022 8:48 am Post subject: |
Wytytt(§
cedrik
Posted: Fri Nov 04, 2022 5:55 pm Post subject: |
| Williac wrote: | | Was able to successfully delid | Which method is the best, to avoid breaking the die? Thanks _________________ https://www.facebook.com/CPUCollectionRO |
Williac
Posted: Fri Nov 04, 2022 7:00 pm Post subject: |
| cedrik wrote: | | Williac wrote: | | Was able to successfully delid | Which method is the best, to avoid breaking the die? Thanks |
Depends on time, risk appetite, and available tools.
Butane / crème brûlée torch - Fast, higher risk. Especially on cooldown.
Heat gun with adjustable temp - moderate speed, moderate risk. Can delid most CPUs with heat spreaders at 600-1100F, but contingent on bonding material.
Convection / broiler oven. Slow, lowest risk, limited temperature. For anything with solder (including silver tin solder) this works well. A solid 5-10 minutes at around 500F. I’ve been doing this to delid ceramic gold chips without issue in most cases. Don’t use one that you plan to ever use again for food. I was fortunate enough to get a used one for free, and it has been handy.
The convection oven has the added benefit of being able to cool more slowly, reducing likelihood of fracturing the ceramic or die. |
dennydo
