Nehalem/Bloomfield i7 vs i7-Extreme
H3nrik V!
PostPosted: Thu Mar 02, 2023 11:29 am    Post subject: Nehalem/Bloomfield i7 vs i7-Extreme Reply with quote
So, inspired by John's recent i7-975x sale, https://www.cpu-world.com/forum/viewtopic.php?t=38036 i got to think of it, that the first generation Extemes were merely 6.4 GT/s vs. 4.8 GT/s speed on the QPI interface (and as far as I can tell, maybe also unlocked multiplier?).
But how much difference does the faster QPI make? I can't find any reviews, could anyone chime in with something? Ideally, a head to head between i7-960 and i7-965x would be cool Wink
svmlegacy
PostPosted: Thu Mar 02, 2023 6:16 pm    Post subject: Reply with quote
Can confirm the extreme editions had an unlocked multiplier (a bit moot considering the BCLK was freely adjustable, but it was there, and allowed for more refined OC'ing)
Can't speak much to the QPI clock differences at this time.
H3nrik V!
PostPosted: Fri Mar 03, 2023 1:31 am    Post subject: Reply with quote
Yeah, since there's no FSB, I imagine that overclocking BCLK would be pretty "safe" no matter.
As for what I can see, the faster QPI link should only matter in regards to peripheral speeds, i.e. graphics, I/O etc., and where it would really shine is in multi socket platforms ...
Calbris
PostPosted: Fri Mar 03, 2023 7:19 am    Post subject: Re: Nehalem/Bloomfield i7 vs i7-Extreme Reply with quote
Have a look at this old review from 2008: https://bit-tech.net/reviews/tech/cpus/intel-core-i7-920-945-965-review/4/
Assuming this is an X58 platform and not a P55 platform, yes. A faster QPI link would only benefit devices that are directly connected to the 82X58 hub, however. Anything that is connected to the ICH10(R) will not as they are linked to the 82X58 via a separate link, you'd still be bottlenecked by a slow DMI link. The gains would be very minimal at best.
svmlegacy
PostPosted: Fri Mar 03, 2023 8:19 am    Post subject: Reply with quote
I'd think the QPI speed is much more important on dual socket LGA1366 systems.
Again, X58 is saved by its flexible BCLK, when OC'ing a processor in this way, the QPI speed can be raised.
P55 / LGA1156 doesn't use QPI at all, instead uses DMI.
H3nrik V!
PostPosted: Fri Mar 03, 2023 8:47 am    Post subject: Re: Nehalem/Bloomfield i7 vs i7-Extreme Reply with quote
Yes, it is X58.
It seems that faster QPI could remove a bit bottlenecks regarding PCI-Express bus.
H3nrik V!
PostPosted: Fri Mar 03, 2023 8:47 am    Post subject: Reply with quote
Yes, from what I could read, I also got the understanding that faster QPI would be most valuable for multi socket systems.
Calbris
PostPosted: Fri Mar 03, 2023 10:22 am    Post subject: Re: Nehalem/Bloomfield i7 vs i7-Extreme Reply with quote
I know this is a little bit off-topic, but wasn't Clarkdale an LGA1156-compatible architecture that utilized QPI to communicate from its memory controller + graphics core to the processor cores? My memory's rusty on this part.
svmlegacy
PostPosted: Fri Mar 03, 2023 10:25 am    Post subject: Re: Nehalem/Bloomfield i7 vs i7-Extreme Reply with quote
You are correct, forgot about this little technicality.
crazybubba64
PostPosted: Fri Mar 03, 2023 11:20 am    Post subject: Reply with quote
Might be easier to do some comparisons using the more widely-available Xeon analogs for the i7 parts. (heck of a lot cheaper too)
These Xeon parts even have unlocked multipliers, just like their i7 counterparts. The only difference I can think of between the two is ECC memory support on the Xeons.
Core i7-965 SLBCJ = Xeon W3570 SLBES
Core i7-975 SLBEQ = Xeon W3580 SLBET
Core i7-980X SLBUZ = Xeon W3680 SLBV2
Core i7-990X SLBVZ = Xeon W3690 SLBW2
The theoretical i7-995X does not have any known retail Xeon counterpart.
My collection
PostPosted: Sun Mar 05, 2023 5:34 pm    Post subject: Reply with quote
That's correct. To be sure, you just have to check their ordering code. If the digits are the same, the validation process is the same (then specific features are fused-down in the last step to make them a Core or a Xeon).
Here we have :
Core i7-965 SLBCJ (AT80601000918AA) = Xeon W3570 SLBES (AT80601000918AB)
Core i7-975 SLBEQ (AT80601002274AA) = Xeon W3580 SLBET (AT80601002274AB)
Core i7-980X SLBUZ (AT80613003543AE) = Xeon W3680 SLBV2 (AT80613003543AF)
Core i7-990X SLBVZ (AT80613005931AA) = Xeon W3690 SLBW2 (AT80613005931AB)
H3nrik V!
PostPosted: Mon Mar 06, 2023 4:45 pm    Post subject: Reply with quote
Thanks for the input ... Better get me some Xeons, though it's kind of cheating Laughing
H3nrik V!
PostPosted: Thu Mar 09, 2023 4:50 am    Post subject: Reply with quote
https://www.cpu-world.com/forum/viewtopic.php?t=34160
Done Laughing
PostPosted: Tue Mar 05, 2024 3:34 pm    Post subject: Reply with quote
hi, would the i7-995X have a counterpart with Xeon X5698 SLC32
crazybubba64
PostPosted: Tue Mar 05, 2024 10:15 pm    Post subject: Reply with quote
X5698 is a 4.4GHz dual-core, the theoretical (ie, very little concrete evidence they exist) i7-995X is a six-core part with a 3.6GHz base clock IIRC.
My collection
