65Sunny65 Guest
Posted: Tue Nov 07, 2023 6:51 am Post subject: CPU Upgrade problem |
Hello,
3 weeks ago i decided to upgrade the CPU of my old Asus X75VD1. It run a Dual Core Intel Pentium B980.
After hours of searches on the web i finally found CPU-Upgrade website. So according to them i noticed that the Intel i7 2760QM notebook Laptop CPU was ok for my laptop.
I received the CPU yesterday and after install every things was ok and i was very happy of the improvement. But suddenly my laptop stop, i restarted, ok again then stop again, i thunk it was heat problem due to a mistake of too much or not enough thermal paste. but after few rebuild i saw it crashed every 30 minutes exactly.
If someone have an explanation and more important a solution i will really appreciate.
Thanks for help ans excuse my french |
Wasmachineman_NL
Posted: Tue Nov 07, 2023 7:15 am Post subject: |
| That's a chipset limitation IIRC, put in a unsupported CPU and Intel ME will kill your laptop after 30 minutes. |
Posted: Fri Nov 10, 2023 4:05 am Post subject: |
hello,
Thank you for your answer;
Does exist a solution to go around this limitation ?
And why in the CPU - Upgrade website they say its compatible ?
Anyway thanks for your time. |
Wasmachineman_NL
Posted: Fri Nov 10, 2023 5:05 am Post subject: |
| Anonymous wrote: | hello,
Anyway thanks for your time. | Not that I know of, unfortunately. |
