Best free software for thoroughly testing SATA drive?
PostPosted: Tue Mar 25, 2025 4:39 pm    Post subject: Best free software for thoroughly testing SATA drive? Reply with quote
I just purchased an 8TB hard drive on eBay, and when it arrives I want to thoroughly test it (SMART status, bad sectors, etc). I'll be testing it in a Skylake system. It'll be storing a large media collection, so I'll be devastated if it fails a month after transferring all my files. What's the best free software you know of to give it a thorough health check? I've never had a drive that I've wanted to do a thorough test on before Smile
PostPosted: Tue Mar 25, 2025 6:23 pm    Post subject: Reply with quote
never mind, I looked at a bunch of reviews, and downloaded SeaTools. Should be perfect, as the new drive is a Seagate. Currently doing an extended test on my old drives before creating a RAID array with them.
max1024
PostPosted: Wed Mar 26, 2025 2:01 pm    Post subject: Reply with quote
You can try Victoria HDD or any other utility that shows SMART at 90%, this will be enough, since by the parameters of the SMART you can already understand what is wrong with the HDD.
Chriscosmo12
PostPosted: Wed Mar 26, 2025 4:48 pm    Post subject: Reply with quote
I have always used CrystalDiskInfo. It gives a good readout on all kinds of SMART stats, drive specs, overall health, etc.
My Collection Archive
misace
PostPosted: Wed Mar 26, 2025 5:27 pm    Post subject: Reply with quote
HD Tune pro 5.75, it is trial, but fully functional. You can reset trial by removing registry keys (delete HKEY_CURRENT_USER\SOFTWARE\EFD Software) and then reinstall.
Looking For Chips 386 J38605DX, Symphony FPU, Rise Tiger, MP6-II, Winchip 3&4, IDT C6-Early Logo, Nx686, Tesla 8088, L80C86, Bulgarian 8088, Pentium 4 QT69ES.
lavrentii
PostPosted: Wed Mar 26, 2025 8:22 pm    Post subject: Reply with quote
But it can still fail. In any case do a backup.
PostPosted: Thu Mar 27, 2025 11:24 am    Post subject: Reply with quote
Thanks for the suggestion. A long test with SeaTools showed no problems with my current drives, so if the 8TB drive tests OK when it arrives, the 2 x 3TB drives will be safe to put in RAID 0. I'll run tests with CrystalDiskInfo as well, to compare the output and time it takes for the most thorough tests.
Chriscosmo12
PostPosted: Thu Mar 27, 2025 1:26 pm    Post subject: Reply with quote
CrystalDiskInfo is pretty instant. You may have to fully format the drive for it to update the SMART statuses. I've gotten info off drives then formatted them and the format corrected some errors. Not sure how other programs work, if they do a deep scan or format on their own.
