Posted: Sun Apr 23, 2006 12:42 pm Post subject: Unknown sSpec |
I ahve a 486DX4ODP100 with sSpec SZ924 that isn't on the site and doesn't show up in a forum search. When I tested it (as mentioned in another thread) it tested fine with a 25MHz bus, but would POST with 33MHz bus, the same as my other 486DX4ODPR100. Not sure if that is a motherboard problem or a chip problem. _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Sun Apr 23, 2006 9:48 pm Post subject: |
Great, I'll add it during next s-spec database update.
sammyc
Joined: 09 Dec 2005 Posts: 1668 Location: Scottish Borders
Posted: Mon Apr 24, 2006 4:55 am Post subject: |
You can add chips to the site yourself Debs. They are not all here - although it must be pretty darn close. _________________ 4000+ chips.
4004-P4. |
Posted: Mon Apr 24, 2006 6:52 am Post subject: |
| sammyc wrote: | | You can add chips to the site yourself Debs. They are not all here - although it must be pretty darn close. |
I didn't realise I could add updates to the site, I never checked as I had assumed not. Thanks _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Mon Apr 24, 2006 7:03 am Post subject: |
I added it as a comment on the page for the 486DX4ODP100, as I can't see another way of adding it. When Genna gets the time for his updates, that is there pending apporval, or however it works  _________________ My graphics card database can be found at http://www.gpuzoo.com.
