Guest Guest
Posted: Thu Jan 22, 2004 4:18 pm Post subject: AMD-K6-333AFR |
Can anyone help with any info about this chip . What I need to know is the bus speed 66mhz or is it 95mhz. The chip is not marked with the speed so I have no idea.
Thanks for any Help. |
Posted: Thu Jan 22, 2004 4:28 pm Post subject: |
It's a 333MHz chip, you can run it with 66 MHz bus x5 or 95 MHz bus x 3.5. If your motherboard does not support 95 MHz bus then try to overclock it a little - use 100 Mhz bus x 3.5.
Genna |
Posted: Fri Jan 23, 2004 1:40 pm Post subject: |
| Thanks for the info Genna. I'ts been very helpful. |
