anheier
Joined: 01 Feb 2003 Posts: 182 Location: Richland, WA
Posted: Sun Mar 02, 2003 12:37 pm Post subject: Unraveling the NEC V-series labeling |
NEC has an interesting, yet confusing processor identification scheme. The V30 is identified as a 8086. The V20 is an 8088. The V40 is an 80186. What about a V25, V35, V45, V50, and V55? Where do these fit?
Norm |
Posted: Sun Mar 02, 2003 1:35 pm Post subject: |
V20 is an 8088 + additional (similar to 80186) instructions + 8080 instruction set.
V25 is a microcontroller version of V20, i.e. V20 + on-chip ROM + on-chip RAM + on-chip peripherals.
V30 is an 8086 + additional (similar to 80186) instructions + 8080 instruction set.
V35 - I don't have datasheet on it, but suspect it's V30 + on-chip ROM + on-chip RAM + on-chip peripherals.
V40 is a V20 + many on-chip peripherals
V50 is a V30 + many on-chip peripherals
I don't have datasheets on V45 and V55.
So, if you look at the instruction set of V20/V30 then you'll see they are closer to 80188/80186 than to 8088/8086. They also a bit faster than 8088/8086.
This reminds me - I need to create separate pages for V20/V30/... processors, I don't think listing them together with other 808x processors is a good idea.
anheier
Posted: Mon Mar 03, 2003 11:55 am Post subject: |
Thanks Gennadiy,
That's what I was getting at. What catagory do these belong in, the 8086, 8088, or the 80186 family . I like your idea of a separate catagory.
Norm |
Posted: Mon Mar 03, 2003 6:12 pm Post subject: |
Putting the chips into single "NEC V-series" category IMHO is better than listing them together with 808x processors. Even better - if you have many Vxx chips then you can create separate category for each type - "V20", "V25", "V30", etc. I don't have many Vxx chips now but I will probably go this route (with multiple categories).
