Is it fake?
pinkie
PostPosted: Tue Jun 06, 2006 9:13 am    Post subject: Is it fake? Reply with quote
I found I have not SB80486DX4-100 in my collection.
And I found one on ebay.
http://cgi.ebay.com.cn/ws/eBayISAPI.dll?ViewItem&item=6887742843&category=95285&rd=1&referrer=http%3A//search.ebay.com.cn/_W0QQfrppZ50QQfrtsZ100QQfsooZ1QQfsopZ1QQrdZ0QQsassZchipsfans#ebayphotohosting
But I thought it's a fake.
Is it a fake chip?
Thank you.
Yan
PostPosted: Tue Jun 06, 2006 9:38 am    Post subject: Reply with quote
The SX920 on this site is an SB80486DX2-50. CPUShack has the same. Unless the sSpec was reused (that sometimes happens...) it is a fake.
Another thing that has me thinking it is a fake is the heights of the characters. The digits are taller than the letters, and that is not normal on the Intel chips I checked.
PostPosted: Tue Jun 06, 2006 9:50 am    Post subject: Reply with quote
thats a fake, the print on 'Intel' is horribly bad, typical of fakes.
PostPosted: Tue Jun 06, 2006 9:56 am    Post subject: Reply with quote
I have seen several speeds with the same spec on ebay, all QFP out of interest. I never won the auctions, I was always beaten by the high rollers. Anyway.. here is my SX920
one from the auction...
PostPosted: Tue Jun 06, 2006 9:59 am    Post subject: Reply with quote
I can't see your picture...
In my opinion the SB80486DX4-100 is a fake.
pinkie
PostPosted: Tue Jun 06, 2006 11:03 am    Post subject: Reply with quote
Thanks all for information.
Did intel change the prefix SB to FC of plastic QFP 486 after DX2-66.
Yan
Yan
PostPosted: Tue Jun 06, 2006 12:08 pm    Post subject: Reply with quote
FC are not completely plastic, but have a big metalic plate on the top.
That is the reason of naming change from SB to FC
jrmunro
PostPosted: Tue Jun 06, 2006 10:34 pm    Post subject: Reply with quote
My SB80486DX2-50 has sspec of SX325. It is mounted on a small board
that I got from a laptop. I couldn`t find SX325 on Genna`s spec finder.
John
PostPosted: Tue Jun 06, 2006 10:57 pm    Post subject: Reply with quote
I'll add it. Does it say "&E3V1X" on the third line?
jrmunro
PostPosted: Tue Jun 06, 2006 11:59 pm    Post subject: Reply with quote
Yes it says "&E3V1X" on the third line.
John
T-HEX
PostPosted: Wed Jun 07, 2006 8:38 am    Post subject: Reply with quote
Green plate and wires on this chip is very similar to Cyrix 5x86.
http://livejournal.com/community/hardware_museum/
PostPosted: Wed Jun 07, 2006 8:46 am    Post subject: Reply with quote
I have this one in the library that is very similar to the fake Intel. But its a 100 Mhz also. Could the remarking be for the brand only? Intel was more expensive than the Cyrix?
/T
PostPosted: Wed Jun 07, 2006 10:45 am    Post subject: Reply with quote
A simple CPUID test using any respectable CPUID app will show if it is an Intel/AMD or a Cyrix/clone chip, as the two have different features and identification routines.
