Anyone playing golf? What are these called?
PostPosted: Thu Jun 08, 2006 10:55 am    Post subject: Anyone playing golf? What are these called? Reply with quote
Got some Intel stuff and have no clue what they are called in english (not in swedish either)... And i canīt put them up on my page as repair-the-golf-green-thingy or golfball-stand Wink
PostPosted: Thu Jun 08, 2006 11:21 am    Post subject: Reply with quote
the sticks are "golf tee's" you put them in the ground, then put the ball on top.... then hit the*&@k out of the ball.
and that is the extent of my golfing knowledge
PostPosted: Thu Jun 08, 2006 11:23 am    Post subject: Reply with quote
The forks look like levers to remove a golf tee
PostPosted: Thu Jun 08, 2006 11:24 am    Post subject: Reply with quote
and the buttons.. hmm... ball locator or whatever its called when you remove your ball from the green
Robev
PostPosted: Thu Jun 08, 2006 9:34 pm    Post subject: Reply with quote
Very Happy The Forked items are "Divot Repairers" for when a ball landing on the Green from a great height leaves a dimple or divot in the ground.
The Buttons are "Ball Markers".
The Sticks are "Tees".
Cheers
PostPosted: Fri Jun 09, 2006 12:07 am    Post subject: Reply with quote
Cheers
Solved!
FDIV
PostPosted: Fri Jun 09, 2006 10:48 pm    Post subject: Reply with quote
That ball mark repair tool on the left is quite nice. It appears that the intel logo may be removed from the rest of the item and used as a ball marker. Is this the case?
PostPosted: Sat Jun 10, 2006 3:38 am    Post subject: Reply with quote
Yupp, its a built in marker there.
