Reduction for Socket 4?
Sten
PostPosted: Thu Jul 06, 2006 12:06 pm    Post subject: Reduction for Socket 4? Reply with quote
Hi all, do you have any idea for what`s it good for? It`s reduction for Socket 4. So maybe it should be some kind of voltage regulator?
Please advise
Thanks Cool
Best Rgrds
Sten
fRaSsL
PostPosted: Fri Jul 07, 2006 11:25 am    Post subject: Reply with quote
Have the same module twice here Very Happy
Frank.
PostPosted: Fri Jul 07, 2006 1:17 pm    Post subject: Reply with quote
Think I thinking about sense of this adapter ... I can't get any idea ... I would use it as pin protector.
Root
PostPosted: Fri Jul 07, 2006 2:54 pm    Post subject: Reply with quote
I've searched info by IBM part number (11H6213 & 11H5591) and google says that this is "Pentium 60Mhz" or "P133 PROCESSOR" Laughing but this is strange Think
FreeBSD - forever
Blackfury
PostPosted: Fri Jul 07, 2006 6:50 pm    Post subject: Reply with quote
hi there
i think it's a Riser
VIA C3 Processor Forever
FDIV
PostPosted: Sat Jul 08, 2006 3:41 pm    Post subject: Reply with quote
This is purely a hypothesis but I think it might have been used for testing purposes. It seams to run leads out from the pins to a place where a probe could have been used.
samnmax
PostPosted: Sat Jul 08, 2006 5:49 pm    Post subject: Reply with quote
I also have one, it came with a P60 off eBay. The seller called it "voltage stabilization board", but that may be only a guess. There are only resistors on it, so to me it looks like a quick fix to a motherboard design problem.
