| Desoldered or Not |
| Yes I Prefer SMD chips desoldered |
70% |
[ 12 ] |
| No, I prefer the whole board, or cut out around the chip |
29% |
[ 5 ] |
| Total Votes : 17 |
tlccomp
Joined: 11 May 2006 Posts: 1212 Location: Southeast Wisconsin, USA
Posted: Sun Jul 09, 2006 1:35 pm Post subject: Question, opinions or maybe even a poll? |
When dealing with surface mount chips soldered on boards
is the preference to desolder them or to cut the board up
around the chip using a bandsaw?
I would be interested to hear everyone's thoughts.  |
Posted: Sun Jul 09, 2006 1:45 pm Post subject: |
Definitely desolder is my opinion. My life without heat gun is same as without one hand  _________________ Visit ABC CPU - Virtual CPU Museum. |
Posted: Sun Jul 09, 2006 1:51 pm Post subject: |
I always prefer to keep the board if possible, showing the chip in context, but many boards are big, so this is not always an option. I prefer a clean cut of the board around the chip with some space. A bandsaw will do this nicely - watch your fingers!
I do not like SMD chips loose, the pins are too easily damaged and they look bad. A chip on a bit of board looks much nicer. |
Posted: Sun Jul 09, 2006 2:25 pm Post subject: |
I don't like desoldered chips unless I consider them really rare. I prefer to either have NOS or the whole board so I ahve a chance of testing my chips. A chip that would cost 100's of $$$ might be acceptable if carefully desoldered, as at that sort of value the chip will still have some value (but only if carefully removed and not damaged from too much heat - I like working chips more than just pretty). _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Sun Jul 09, 2006 4:29 pm Post subject: |
| CPUShack wrote: | | desoldered for sure, |
why? |
Posted: Sun Jul 09, 2006 4:42 pm Post subject: |
| JAC wrote: | | CPUShack wrote: | | desoldered for sure, |
why? |
eaiser to display and easier to store, when you have over 2500 chips, boards layin around takes up ALOT of room.
I prefer them NOS, but if not I'll remove them from boards so they are closer to NOS condition. _________________ New for 2025! The CPU Shack has a co-processor!
Posted: Sun Jul 09, 2006 4:56 pm Post subject: |
| CPUShack wrote: | | JAC wrote: | | CPUShack wrote: | | desoldered for sure, |
why? |
I prefer them NOS, but if not I'll remove them from boards so they are closer to NOS condition. |
Surely if the board is cut around the chip then space is not really an issue?
I know you have many chips, how do you store your SMD chips? I have many and without the tray/pockets several have had their pins bent from moving.
I think it is too much of a risk to take them off the board. A SMD chip on a small board is worth more to me than a desoldered SMD chips with a pin missing.
jd
Posted: Sun Jul 09, 2006 5:19 pm Post subject: |
Doesn't make a bit of difference to me, if I find that theres a bit of solder left on the chip and it bothers me that badly, I simply take out the gun and clean it !
...no big deal really
Sometimes tho, I will actualy prefer it left onboard for better preservation, and pending on the enviroment the chip is surrounded by!
JD |
Posted: Sun Jul 09, 2006 5:42 pm Post subject: |
I have part of a tray for PQFP80 chips (enough for 30 chips) and two trays for PQFP196 chips (21 chips per tray), so for me keeping them in good condition is easy (until I get too many for the amount of trays, that is...). Of course, there are other sizes that I don't yet have trays for  _________________ My graphics card database can be found at http://www.gpuzoo.com.
Oddie_
Joined: 16 Feb 2006 Posts: 55 Location: SPAIN (Valencia - Espaņa)
Posted: Sun Jul 09, 2006 7:41 pm Post subject: |
| JAC wrote: | I always prefer to keep the board if possible, showing the chip in context, but many boards are big, so this is not always an option. I prefer a clean cut of the board around the chip with some space. A bandsaw will do this nicely - watch your fingers!
I think the same. A clean cut of the board around the chip is nicer. |
FDIV
Posted: Mon Jul 10, 2006 12:41 am Post subject: |
| I usualy desolder because I think they look like crap with little poorly cut peices of board hanging on them. Occasionally I will also cut the leads with a utility knife as close to the board as possible. I might change my method if I found a chip that had substantial value though. Most are hardly worth anything. |
Posted: Mon Jul 10, 2006 2:51 am Post subject: |
| I display mine electronically, so it is easy to crop to the chip view, I dont mind a bit of hacked board. |
Posted: Mon Jul 10, 2006 3:53 am Post subject: |
Most of chips have description from two sides. How we check bottom when it will be soldered ? Agree with CPUShack soldered means more heavy, harder to storage. _________________ Visit ABC CPU - Virtual CPU Museum. |
