Posted: Fri Jul 14, 2006 10:46 am Post subject: Blow torch, oven or? |
How do you remove chips soldered into a board?
Oven - bake and shake? 200 degrees c - I dont like this and I dont have an old oven to stink out.
Blow torch - like a small plumber gas torch. gets too hot
.. other? |
pinkie
Joined: 17 Sep 2005 Posts: 971 Location: Shenzhen,GD,China
Posted: Fri Jul 14, 2006 11:14 am Post subject: |
I think hot air gun can do it well.
Yan _________________ Yan |
chip68
Joined: 19 Oct 2004 Posts: 1024 Location: Central Pennsylvania
Posted: Fri Jul 14, 2006 11:17 am Post subject: |
Either a soldering iron and solder sucker, or a hot air gun and forceps (works best for surface-mount components).
I do hope you're joking about ovens and blow torches, btw...
- CMW |
Posted: Fri Jul 14, 2006 11:28 am Post subject: |
| chip68 wrote: | Either a soldering iron and solder sucker, or a hot air gun and forceps (works best for surface-mount components).
- CMW |
heh.. no I am not
I know people who use ovens.. 'bake and shake '
I saw a plumbers blow torch and I know they will get too hot...
Solderiong iron and sucker doesnt work well on THP boards. .. and 100's of pins. |
chip68
Posted: Fri Jul 14, 2006 12:15 pm Post subject: |
| JAC wrote: | | Solderiong iron and sucker doesnt work well on THP boards. |
It does if you have a good, hot soldering iron and enough "suck." I have a vacuum pump desoldering tool that does plated through-hole boards just fine. (Provided the pin count is reasonable, as you already pointed out.)
Using hot air alone on through-hole components often leaves a ton of solder on the pins, which just has to be removed later.
| JAC wrote: | I know people who use ovens.. 'bake and shake '  |
Sounds a mite dangerous... Besides, everybody knows the best way to cook chips is by frying them.
- CMW |
