CPU or chip removal from motherboards
Tomike00
PostPosted: Sun Feb 15, 2004 8:56 am    Post subject: CPU or chip removal from motherboards Reply with quote
Hello, Very Happy
I'm new to this hobby of collecting CPU's. My question is: how can I safely remove processors from the motherboards they're installed on without damage to the processor (and Mboard if possible)?
Also, some CPU's I've collected have the heat sink glued on them. How do I remove this without damaging the chip, or markings on the chip?
Thanks in advance for your time!
redbaron
PostPosted: Sun Feb 15, 2004 11:50 am    Post subject: Reply with quote
Hi!
For removing heat sinks, take a look at this forum entry at cpu-museum.de
http://www.cpu-museum.de/forum/viewtopic.php?t=224
Usually, the scredriver/knife method will work (insert and rotate the device).
Good luck!
redbaron
morkork
PostPosted: Sun Feb 15, 2004 1:06 pm    Post subject: Re: CPU or chip removal from motherboards Reply with quote
The best tool for this is a chip puller. You can get it for cheap at your local electronics store. But normally a skrewdriver or a knife will do as well. Insert it between the chip and the socket and gently lift the chip for just a few millimeters. Go to the opposite side of the chip and repeat. Don't lift it too far or the pins might bend. Just lift a little bit on each side of the chip until it gets loose.
..::morkork::..
http://cpu-collection.de
PostPosted: Sun Feb 15, 2004 9:55 pm    Post subject: Reply with quote
Freezing them can help weaken the glue on heatsinks as well
