Guest3258 Guest
Posted: Mon Jul 31, 2006 1:10 pm Post subject: laptop cpu change / upgrade |
Hey guys.
My dad has a laptop (patriot 3070).
"pcservicecall.co.uk/layout.aspx?ID={dfd7f6ef-7064-49d2-b317-4f4e25b65808}&CatID={fe2d3c68-2efc-4083-a3ef-ea6e5a0d2558}"
I was going to buy him a AMD athlon 2.4 CPU to put in it.....will this work? I know very little about PCs / laptops
Very sorry for the very simple question.
Thanks in advance
Dave |
Posted: Mon Jul 31, 2006 1:23 pm Post subject: |
Your link not work.
Don't be mad but if you know little about laptops then changing CPU can be very difficult for you. _________________ Visit ABC CPU - Virtual CPU Museum. |
Guest358 Guest
Posted: Mon Jul 31, 2006 2:00 pm Post subject: |
the link needs the World Wide Web infront of it, but as a guest im not allowed links.
Im not mad...i will pay for sum1 to do the work, i just dont wanna look a fool with a CPU that he cant use.
Is it possible to fit aCPU that would fit in a desktop motherboard into a laptop motherboard?
Thanks in advance |
Posted: Mon Jul 31, 2006 2:53 pm Post subject: |
You can use only mobile versions to fit into laptop. In most case you can fit all mobiles in desktop. Athlon XP mobile is marked as XP-M _________________ Visit ABC CPU - Virtual CPU Museum. |
