My small PC
PostPosted: Sat Aug 05, 2006 2:16 pm    Post subject: My small PC Reply with quote
Hi
I prepare to sale my notebook. Before I will choose Intel Core2 Duo or AMD X2 I working on that nanoPC. Original that was terminal with Windows CE. I bought 2,5" HDD and adapter to IDE. Upgraded RAm from 64 MB to 512. Second adapter USB2.0 to IDE to plug DVDRW. PC have dimension : 25x27x5 cm Smile All passive cooling inside. Specification :
Motherboard : Gigabyte P3VB (embedded)
CPU : VIA C3 Samuel 2
RAM : 2 x 256 MB PC133
HDD : WD Scorpio 40 GB
AUDIO, LAN, VGA (Trident AGP 4x) integrated
Works quiet with XP Professional SP1 Very Happy
diodak
PostPosted: Tue Aug 08, 2006 1:44 am    Post subject: Reply with quote
Nice one, this computer looks like my cable modem for internet Smile
You see lots of happy cyclists. When was the last time you saw a runner smiling? - forum szosowe
PostPosted: Tue Aug 08, 2006 3:27 am    Post subject: Reply with quote
yeah looks good..
look at this toy..
http://gadgets.fosfor.se/space-cube-tiny-pc/
TCWORLD
PostPosted: Mon Aug 10, 2009 3:40 pm    Post subject: Reply with quote
I've just found this. I have rcently bought one of these boards (Gigabte P3VB) on eBay, however havent got a manual for it, nor can find much information. I know this post is 3 years old, but if you happen to still have an electronic copy of the manual, I would b most grateful.
PostPosted: Tue Aug 11, 2009 12:07 am    Post subject: Reply with quote
You cann't find manual because it is Gigabyte OEM product. What you need to know ?
TCWORLD
PostPosted: Wed Aug 12, 2009 11:22 am    Post subject: Reply with quote
Sorry for the delay in getting back, forgot what the web address was.
Just sort of general Info really, Pinouts of the onboard connectors, such as the front panel connectors.
Thanks in advance.
Wizzard1
PostPosted: Wed Aug 12, 2009 11:45 am    Post subject: Reply with quote
@TCWORLD:
http://cerberus.teamhackaday.com/?p=64
TCWORLD
PostPosted: Wed Aug 12, 2009 3:19 pm    Post subject: Reply with quote
Thanks for that. I found that after a while of searching. I also managed to get one vital piece of information from the place i bought the m'board... The pinout of th F_Panel connector. I thought the m'board was faulty as it wouldn't boot, and it turns out that the connector markd by the web address you posted is the USB connector, and hence i wasn't actually turning the board on, just shorting the USB port :duh:
Cerberus
PostPosted: Wed Aug 12, 2009 7:24 pm    Post subject: Reply with quote
Sorry about that. It was a stupid mistake on my part that is now corrected. Thanks for stopping by.
TCWORLD
PostPosted: Sat Aug 15, 2009 10:12 am    Post subject: Reply with quote
No problem, didn't mean to criticise.
