lmcphee Guest
Posted: Sat Aug 19, 2006 10:28 am Post subject: socket 462 - tab for heat sink broken |
The CoolMaster HeatSink is held using two centre tabs on either side of the 462 socket. One centre tab broke off. So I can either a) replace the 462 socket or b) leave the socket as is and find a heatsink that uses the "outer" tabs on the socket.
Suggestions welcome on where I can buy the 462 socket and/or a heatsink to fit the 462 socket. |
Posted: Mon Aug 21, 2006 12:28 am Post subject: Re: socket 462 - tab for heat sink broken |
| lmcphee wrote: | | Suggestions welcome on where I can buy the 462 socket and/or a heatsink to fit the 462 socket. |
There are heatsinks that use outer tabs. For example, many ThermalTake heatsinks use all three tabs from each side:
http://www.tr2tt.com/products/coolers/duronandathlon.htm
