Difference in Athlon XPs
Mario283
PostPosted: Tue Aug 29, 2006 6:54 pm    Post subject: Difference in Athlon XPs Reply with quote
Hello all,
I have a question, and I think this would be the best site for me to get the correct answer. I have a Shuttle AK35GTR motherboard, and I want to get the most that I can out of it.
I want to know if I can upgrade it to an Athlon XP 3200+ 400FSB. According to Shuttle the motherboard can be upgraded to an AthlonXP 3000+ 300FSB.
How much difference is there between the two processors? Can I put the 3200+ in and do some overclocking to make up for the 100FSB difference?
Any and all help will be greatly appreciated, and thanks in advance,
Mario
jd
PostPosted: Wed Aug 30, 2006 10:33 am    Post subject: Reply with quote
...funny....
I'm getting that you can only go as high as 200/266 FSB.
Hence the highest available chip for you would be the:
Athlon XP-M 3000+(mobile)
or
Athlon 2800+ (AXDA2800DKV4C)(desktop)
JD
Mario283
PostPosted: Wed Aug 30, 2006 2:17 pm    Post subject: Reply with quote
...odd....
From what I get out of Bios revision AK35S20G (see below) I can upgrade to an Athlon XP 3000+. Please note that it states nothing about the XP-M 3000+. I found a 3000+ at Zipzoomfly and the FSB is 300. Am I missing something?
Also note that the default FSB in the bios is 133, and I can raise it in increments of 1MHz to 200 FSB; hence my question can I put in an Athlon XP with a higher FSB and raise the FSB higher than 133 in the Bios?
Bios name
Remarks
AK35S20A
Date code: 03/22/2002 checksum: CC00
Initial release.
AK35S20B
Date code: 04/03/2002 checksum: 1A00
Fixed when resume from s3 the 2nd time will fail if modify CPU mutiplier.
AK35S20C
Date code:04/12/2002 checksum : E100
Fixed SFF Duron cpu name string show error.
AK35S20D
Date code:08/30/2002 checksum : FD00
1. Support AthlonXP (CPUID=681h) 2400+ & 2700+ CPU
2. add CPU Clock table to (166MHz ~ 200MHz)
AK35S20E
Date code: 09/10/2002 checksum : 0C00
1. FSB default is 133MHz if use AthlonXP CPU
AK35S20F
Date : 12/19/2002 checksum : 0E00
1. Set FSB166 RomSip table is normal mode.
2. Support AthlonXP 2500+ & 2800+ (CPUID=6A0h) Barton CPU.
AK35S20G
Date : 01/16/2003 checksum : 5B00
1. Support AthlonXP 3000+ CPU
AK35S20H
Date : 09/12/2003 checksum : F700
1. Support Thorton CPU
AK35S20I
Date : 12/05/2003 checksum : 4000
1. Support Duron 1.3G Palomino CPU
AK35S20L
Date : 08/09/2004 checksum : 1A00
1. Support K7 Sempron CPU
jd
PostPosted: Wed Aug 30, 2006 2:29 pm    Post subject: Reply with quote
...on top you only put --> AK35GTR
That leaves alot of different versions to find Wink
But ya,, the 133fsb is actually @ x2 for 266fsb max.
The reason why you see the 3000+ is that it is a moblie chip.
-->Athlon XP-M 3000+ 2200 MHz /512 KiB /266fsb MT/s /16.5x(multiplier) / 1.65 2003 AXMA3000FKT4C
Hence you cannot put your "FSB" any higher then 266.according to your motherboard statistics, unless I missed something Wink .
the Highest CPU found @ 266 is the indeed the mobile one.
Here ,for more info on other CPU's
go here
------> http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Mario283
PostPosted: Wed Aug 30, 2006 2:38 pm    Post subject: Reply with quote
My apologies, I forgot to thank you for your previous post.
If you are referring to the Bios revision, I have the latest one, AK35S20L. I should have included it in my initial post.
Thanks again,
Mario
jd
PostPosted: Wed Aug 30, 2006 2:40 pm    Post subject: Reply with quote
I edited my post for more cpu ideas
go check it might help you more on what chip to buy!
Later
JD
PostPosted: Wed Aug 30, 2006 8:46 pm    Post subject: Reply with quote
I agree with JD - even though your board can be overclocked to 200 MHz FSB, it officially supports only 200 and 266 MHz FSB processors, which means that mobile Athlon XP-M with Thorton core is the fastest processor you can use in the board.
