keltro Guest
Posted: Sun Sep 17, 2006 5:00 pm Post subject: MY CPU IS OVERHEATING |
| I have a 3ghz CPU.. Fan is working at 2700 RPM and the Chassis fan is working at 2000 RPM.. THe pc hasn't been clocked. It is going as far as 170, 180 F Degrees and then the pc shuts down itself.. I like to know if the fans are in normal speed, or what can I do to cool down the cpu?will the cpu need to be replaced... I have tryied a 2ghz cpu and is working fine.. Is under 96F. and when is not been worked on is around the 70s |
slava
Joined: 24 Jul 2005 Posts: 379 Location: Dnipro, Ukraine
Posted: Tue Sep 19, 2006 2:03 am Post subject: |
Remove the CPU and put some thermal paste under it if you haven't yet done so. If this doesn't help, you should get a new CPU cooler. My Athlon XP 3000+ is currently cooled by Thermaltake Volcano 12. _________________ Collecting soviet and western CPUs once again -- highfive to old-timers o/ |
