XP Pro and Pentium Pro
PostPosted: Tue Sep 26, 2006 6:18 am    Post subject: XP Pro and Pentium Pro Reply with quote
This is probably a question for Frank, the pentium pro king.. Very Happy
Does anyone run Xp on a pentium pro system ( single, dual or quad cpu) ?
Does it work ok? etc..
fRaSsL
PostPosted: Tue Sep 26, 2006 6:48 am    Post subject: Reply with quote
Why should it not work Smile But Quad systems... hmm... dunno whether XP takes 4 CPU or not. I believe no. I used Win2000 AS or ES.
Frank.
PostPosted: Tue Sep 26, 2006 7:11 am    Post subject: Reply with quote
My experience is not good with multiple cpu. I have a request for some simple computers. ( i.e. FREE ) .. and I have some pentium pro parts so it makes sense! I thought I would try it and see if it worked ok. I found some posts on usenet that said it works ok for some, but not for others.
I traded all my pentium pro overdrives 333Mhz, so I am also looking for one if anyone has one! Smile
PostPosted: Tue Sep 26, 2006 10:42 am    Post subject: Reply with quote
XP Home - max 1 CPU
XP PRO - max 2 CPUs
2000/2000 Pro/Server - max 2 CPUs
2000 Advanced Server - max 8 CPUs
I used 2000 Advanced Server on Quad Pentium Pro. Works very well Wink
PS I looking for Pentium II Overdrive 333 too.
picur10
PostPosted: Tue Sep 26, 2006 10:55 am    Post subject: Reply with quote
So If I want to use a dual core cpu then I need XP Pro? Embarassed Question
fRaSsL
PostPosted: Tue Sep 26, 2006 11:30 am    Post subject: Reply with quote
Yes and no. It's legal to do some tricks that make your home edition to a Pro Edition. But I don't recommend XP for playing around. Win2k is much faster on old machines Smile
Frank.
PostPosted: Tue Sep 26, 2006 12:05 pm    Post subject: Reply with quote
Especially 2k not need good VGA card what is problem on old machines especially Quad server systems. No XP for Pentium Pro ! Wink
PostPosted: Tue Sep 26, 2006 12:39 pm    Post subject: Reply with quote
ah.. I forgot completely about Win2K.. I'll use that.
Oddie_
PostPosted: Fri Oct 13, 2006 7:04 am    Post subject: Reply with quote
I have a Fujitsu-Siemens server based on a P-Pro 200/256KB .I added 256MB RAM 72c (2x64MB + 4x32MB) and now it's running Windows XP Pro perfectly.
The performance is a little slow but it runs good to work.
PostPosted: Sat Oct 14, 2006 3:07 am    Post subject: Reply with quote
I have a dual Xeon 2.66 GHz machine. Each of the CPUs supports hyperthreading. Windows 2000 Pro used to see only two processors, but after I installed XP Pro, 4 of them were reported.
I believe that Microsoft changed its licensing so the numbers mentionned above apply to physical processors rather than cores or logical processors a few years ago.
It's probably easy to find a definitive response to this on the web.
[edit - see http://www.microsoft.com/licensing/highlights/multicore.mspx]
Hippo
PostPosted: Sat Oct 14, 2006 5:49 am    Post subject: Reply with quote
Funny you should ask that..
http://www.prog-tech.co.uk/blog/
PostPosted: Sat Oct 14, 2006 7:32 am    Post subject: Reply with quote
hey hippo.. wondered where you were.. nice layout html!
