H/S question
PostPosted: Fri Oct 06, 2006 7:09 pm    Post subject: H/S question Reply with quote
Will a celeron 366 heatsink+fan work for a celeron 400?
I want to upgrade my friend's pc, for office use, to make it go a little faster. This said I already put the maximum amount of supported ram and I can see the results Smile
Thanks.
PostPosted: Fri Oct 06, 2006 7:16 pm    Post subject: Reply with quote
yup, the 366 fan/hs would work fine through a Celeron 533 or so.
PostPosted: Sat Oct 07, 2006 6:23 am    Post subject: Reply with quote
Thank you.
