Machine Language for CPUs Needed!
UNoHoo
PostPosted: Sun Nov 12, 2006 2:15 pm    Post subject: Machine Language for CPUs Needed! Reply with quote
Hello!
I was wondering where I can find a chart, table, or something that can show the corresponding machine language code next to the assembly code for a Motorola 68000 or Zilog Z80 CPU.
~UNoHoo
PostPosted: Sun Nov 12, 2006 5:44 pm    Post subject: Re: Machine Language for CPUs Needed! Reply with quote
You can download Z80 user manual from Zilog site:
http://www.zilog.com/products/partdetails.asp?id=Z84C00
It has a list of all instructions, and it gives binary representation for each instruction.
UNoHoo
PostPosted: Sun Nov 12, 2006 6:37 pm    Post subject: Reply with quote
Hey, thanks! That's exactly what I needed! And the funny thing is that I was actually at that site, but didn't bother to check those manuals!
Thanks again!
PostPosted: Sun Nov 12, 2006 7:02 pm    Post subject: Reply with quote
Here is a link for programmer's reference manual for Motorola 68000:
http://www.freescale.com/files/archives/doc/ref_manual/M68000PRM.pdf
Binary codes you will find in chapter 8 of the manual.
chip68
PostPosted: Sun Nov 12, 2006 9:36 pm    Post subject: Re: Machine Language for CPUs Needed! Reply with quote
Right here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270053377763
- CMW
