sadako
Posted: Thu Nov 30, 2006 2:45 am Post subject: Motherboard for Athlon XP-M 2008 |
First, sorry for my english..
Second :
I have a Asus A7N8X-VM/400 with a Athlon 1600+ with Ubuntu 6.10 (is working very good)
And recently i try to put an Athlon XP-M 2800 on this configuration, but the CPU stay @800Mhz.
The CPU
http://www.cpu-world.com/CPUs/K7/AMD-Mobile%20Athlon%20XP-M%202800%2B%20-%20AXMA2800FKT4C.html
Is a Hardware or Software problem ?
If i can't put the Athlon XP-M 2800 on the Asus A7N8X-VM/400, can you say me what motherboard i can use for the CPU ?
Thanks a lot |
Posted: Thu Nov 30, 2006 3:07 pm Post subject: |
Maybe your BIOS doesn't recognize the CPU and doesn't set correct bus speed and clock multiplier... Try to set bus speed and multiplier manually in the BIOS.
sadako
Posted: Fri Dec 01, 2006 7:53 am Post subject: |
hmm
That my problem, i have the last Bios release, and for this MotherBoard, i can't change anymore...
The CPU is autodetected and that all .
So thank you .
I'll try to find another motherboard for this CPU, if you are an advise about motherboard for this CPU, thanks by advance !
bye ! |
Bugan
Posted: Sat Dec 09, 2006 5:00 am Post subject: Re: Motherboard for Athlon XP-M 2008 |
| sadako wrote: | I have a Asus A7N8X-VM/400 with a Athlon 1600+ with Ubuntu 6.10 (is working very good)
Is a Hardware or Software problem ? | Hi Sadako,
As the manual of your Mobo in the page 8 tells Your Mobo can only with Athlon 2700XP+ work
There are no Jumper and no configuration over BIOS.
The only thing that you can do is check with a 400 Mhs memory .... Just try  _________________ Antonio Bugan |
sadako
Posted: Mon Dec 11, 2006 10:22 am Post subject: |
Thank Bugan !
But , now i'm going to another way, i try to find a MotherBoard for this CPU, it's more simple.
So if you know a good motherboard for an Athlon XP-M 2800+
Thanks a lot all ! |
Posted: Mon Dec 11, 2006 10:54 am Post subject: |
Try to use this program to set Athlon XP-M multiplier from Windows:
http://www.cpuheat.wz.cz/html/CPUMSR_main.htm
As for the motherboard - I've read that many people use Abit NF7/NF7S with Athlon XP-Ms, I don't know if that board supports XP-M 2800+ or not.
sadako
