OPGA Thunderbird?
skold
PostPosted: Sat Mar 27, 2004 4:46 am    Post subject: OPGA Thunderbird? Reply with quote
A friend of mine had this a while back:
Its a tbird 900, with an opga package..
I havent seen any of these before or after.. Unfortunately he cracked the core putting a heatsink on backwards.. Rolling Eyes
Has anyone seen any more of these? I'd like to get my hands on one..
I think it was probably some limited oem run or something?
razor1000
PostPosted: Tue Mar 30, 2004 2:03 am    Post subject: Reply with quote
betcha it's a mobile.
I think overclock.de had a serial-number decoder... you could prolly find out that way... i can tell at least that it's a Thunderbir "B" which means 200FSB... no way was there a regular desktop chip at that speed.
skold
PostPosted: Tue Mar 30, 2004 2:12 am    Post subject: Reply with quote
900/200 is unusual? a friend of mine (the same friend, actually, heh) had a 1ghz/200fsb tbird as well.. that one though was on cpga so it wasnt unusual..
the only thing i find unusual about this cpu is the fact that its opga.. i think i even have another cpga tbird with the ARGA stepping..
razor1000
PostPosted: Tue Mar 30, 2004 2:20 am    Post subject: Reply with quote
ARGA is the stepping, I'm talking about the first line...
I don't think I've heard of an "A0900".
And what I meant about the FSB was that you wouldn't find OPGA AND 200FSB on a desktop chip.
razor1000
PostPosted: Tue Mar 30, 2004 4:14 am    Post subject: Reply with quote
EDIT: I meant ocinside.de... here's the link:
http://www.ocinside.de/html/workshop/amd_product_id.html
Minuteman
PostPosted: Tue Mar 30, 2004 4:55 am    Post subject: Reply with quote
About that, does somebody know if AMD has something like Intel's processorfinder?
skold
PostPosted: Tue Mar 30, 2004 6:03 am    Post subject: Reply with quote
doesnt tell me much more than i already know.. Smile
it does say 'model 4' though. athlon 4 maybe? those were only mobile iirc
skold
PostPosted: Sat Apr 16, 2005 9:01 am    Post subject: Reply with quote
just to bump this thread, has anyone come across any of these? i just spent about 2 hours looking on ebay and i havent found squat. Sad
chipcollector
PostPosted: Sat Apr 16, 2005 11:25 am    Post subject: Reply with quote
I have a 1000mhz tbird. Flys like charm
skold
PostPosted: Sat Apr 16, 2005 11:50 am    Post subject: Reply with quote
with an opga package, though?
ive got a half dozen tbirds in my closet, but ive only ever seen one opga one, and it wasnt mine, so..
chipcollector
PostPosted: Sat Apr 16, 2005 12:00 pm    Post subject: Reply with quote
Yes, it is brown Smile
skold
PostPosted: Sat Apr 16, 2005 12:06 pm    Post subject: Reply with quote
scan/pic plz?
PostPosted: Sat Apr 16, 2005 12:07 pm    Post subject: Reply with quote
I'm periodically looking for Athlons/Durons on eBay, and I've never seen 900 MHz Athlon in OPGA package. There are only two references for this processor on the net. BTW, you can buy 1 GHz Athlon in OPGA package for $58.
skold
PostPosted: Sat Apr 16, 2005 12:08 pm    Post subject: Reply with quote
so, the 1ghz ones are common, but 900s arent?
we're still talking thunderbird cores here right?
PostPosted: Sat Apr 16, 2005 12:19 pm    Post subject: Reply with quote
They are rare too.
I don't know, the site only shows part number - A1000DMT3B. Just search fpr this part number.
