Unusual K6-2 stepping (undocumented...)
PostPosted: Wed Dec 13, 2006 10:18 am    Post subject: Unusual K6-2 stepping (undocumented...) Reply with quote
I've been testing some of my chips recently. The socket 7 board I was using (the only one I had which worked and supported chips beyond 250MHz) died, but not before I was able to test the K6-2/300AFR Revision E that I have.
Revision E dosen't exist in any of the revision guides I have for the K6-2, so I suspected it might have been a fake with a marking that would have told it's creator what it was, but on testing it returned a CPUID of 0584, which is also not documented (and which would be far too complicated for someone to try and fake!). Has anyone else come across an undocumented CPUID or revision code on a K6-2? I'm not sure if this is as uncommon as I believe it to be...
Picture of the chip. from my site:
