533 cpu into 400 board?
CaptainSossige
PostPosted: Fri Dec 22, 2006 1:53 pm    Post subject: 533 cpu into 400 board? Reply with quote
I have a P4 Northwood 533 2.4ghz cpu that i want to put into a board that supports 400mhz FSB..
What will happen if I do this...? Will it work...
PostPosted: Fri Dec 22, 2006 1:54 pm    Post subject: Reply with quote
MoBo is AOpen MX46U2-CN with sis650 chipset
PostPosted: Fri Dec 22, 2006 6:47 pm    Post subject: Reply with quote
Yes, but the P4 frequency is given by FSB*cpu clock multiplier, which is locked in Intel cpus.
400 mhz fsb will make your cpu work at a slower frequency.
Because Intel uses quad-pumped bus the real Fsb is 100 mhz for 400 and 133 for 533, 2400/133=18x; 18x100=1800 mhz cpu with 400 mhz fsb.
Hope it solves your problem, goodnight.... yawn
PostPosted: Fri Dec 22, 2006 6:53 pm    Post subject: Reply with quote
http://global.aopen.com.tw/Products/mb/mx46-533v.htm
Does your board look like this? In forums seems it's your same model, but the one you have is oem, baught and renamed.
Should be 533 mhz fsb ready... check in your bios.
