what is multiple VIDs
Blackfury
PostPosted: Wed Feb 21, 2007 8:31 am    Post subject: what is multiple VIDs Reply with quote
SL6VU and other cpu's have multiple VIDs what is that? Embarassed
VIA C3 Processor Forever
PostPosted: Wed Feb 21, 2007 11:04 am    Post subject: Reply with quote
Intel CPUs have voltage identification (VID) pins that tell the motherboard what voltage should be set for this CPU. Some S-specs have fixed core voltage, i.e. their VID pins are always programmed the same way. Other S-Specs may have multiple core voltages, their VID pins are programmed differently depending on their core voltage. These are the chips with multiple VIDs. For these chips CPU-World's or processorfinder's S-Spec pages usually show a range of core voltages.
PostPosted: Wed Feb 21, 2007 11:17 am    Post subject: Reply with quote
very good explanation, thanks
My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum
Blackfury
PostPosted: Wed Feb 21, 2007 12:15 pm    Post subject: Reply with quote
thank you for that info gshv icon_peace Smile
