What the Heck? AMD AthlonXP AXDA1800DKV4C
sign-man
PostPosted: Fri Apr 20, 2007 2:01 pm    Post subject: What the Heck? AMD AthlonXP AXDA1800DKV4C Reply with quote
I just purchased this processor and CPU-World says it may be a Barton Model 10 or a Thoroughbred Model 8.
When I boot up Windows XP will not start (just keeps rebooting my computer) but it works in DOS. AMD's Dos utility Identifies it as a Duron 500mhz Model 10.
I'm using a Gigabyte MB GA-7ZXE rev.1.0
Any help?
PostPosted: Fri Apr 20, 2007 6:11 pm    Post subject: Reply with quote
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=2307
you mean axda2800dkv4c?
either way looks like it ain't supported by your mobo, try a bios update but i'm pretty sure it won't solve a thing
look for a new motherboard that supports barton core cpus
or maybe try a cmos reset
bye
sign-man
PostPosted: Fri Apr 20, 2007 6:28 pm    Post subject: Reply with quote
Here is an image of the label. I have two of these.
picur10
PostPosted: Sat Apr 21, 2007 2:03 am    Post subject: Reply with quote
As I saw it's operate with lower voltage (1.65v). Check your bios setting maybe the board gives too high voltage to the cpu.
