Who has a Pentium-M laptop that could test a CPU for me?
PostPosted: Mon Apr 30, 2007 6:49 pm    Post subject: Who has a Pentium-M laptop that could test a CPU for me? Reply with quote
I have a P-M Q08R, Looks to be dothan core, but I do not know the speed, bus or cache.
I can send one for someone to test.
The die looks to be laser corrected (ie maybe a 2MB part turned into a 1MB part)
Who can help?
Thanks
CPUbar
PostPosted: Mon Apr 30, 2007 8:01 pm    Post subject: Reply with quote
Could you show a picture of your P-M ?
CPUbar
PostPosted: Mon Apr 30, 2007 8:41 pm    Post subject: Reply with quote
Here is one
CPUbar
PostPosted: Mon Apr 30, 2007 11:06 pm    Post subject: Reply with quote
Here is one
If it is a PGA , I can test it . Wink
CPUbar
PostPosted: Tue May 01, 2007 2:22 am    Post subject: Reply with quote
its PGA
CPUbar
PostPosted: Tue May 01, 2007 3:12 am    Post subject: Reply with quote
its PGA
This ES CPU not too hard to find in China. I will search it in our country first. When I get it I will tell you. Thank you.
CPUbar
PostPosted: Tue May 01, 2007 11:28 am    Post subject: Reply with quote
Thank you much
PostPosted: Sun May 06, 2007 12:28 pm    Post subject: Reply with quote
any luck?
CPUbar
PostPosted: Sun May 06, 2007 10:19 pm    Post subject: Reply with quote
I saw some P-M ES but miss your model so far. Sad
CPUbar
PostPosted: Fri Jun 08, 2007 2:43 am    Post subject: Reply with quote
And the answer is :
