Interesting Sun Card w/ Celeron CPU
Windmiller
PostPosted: Sun Jun 17, 2007 8:22 am    Post subject: Interesting Sun Card w/ Celeron CPU Reply with quote
I was surprised when I took the heatsink off to find a Intel cpu underneath. I have never seen this type of setup before, its an interesting setup. How common is it?
PostPosted: Sun Jun 17, 2007 8:50 am    Post subject: Reply with quote
It is probably a PC card called SunPCi that enables you to run x86 apps in a Sun workstation. I had a colleague at work using that i his Sun Ultra5 workstation. The card was running a AMD-K6-2 400. Basically its a complete PC that uses the workstation disk, display and mouse/keyboard.
Some googling suggests that your card is a SunPCi II.
http://www.sun.com/products-n-solutions/hardware/docs/system_options/interop_boards/index.html
Edit: About rarity it seems like there has been a I, II and III version ranging from K6-2 300 to Athlon XP 1600+ so it must have been rather popular since the processors range over a couple of years.
daytona_usa
PostPosted: Thu Jun 21, 2007 2:41 pm    Post subject: Reply with quote
looks like an entire laptop board on a doublewide PCI card.
that my good sir is a very nice board.
Having SEX I gave her the Killer POKE, with an I/O motion till the CDP broke, I got Compact Disc then I logged out, took a f00f on a HCF Smoke, the BSoD Stop Error'ed my WinME, as I started to Kernel Panic and go insane-y. <ch> Insane in the mainframe...
