i've got a pII overdrive,is it a engineer sample?
wuyuetiger
PostPosted: Sun Jun 06, 2004 4:25 am    Post subject: i've got a pII overdrive,is it a engineer sample? Reply with quote
it says PODP66X333 Q0126 ES.
ES means Engineer Sample?
虞越
Simmayor
PostPosted: Sun Jun 06, 2004 6:11 am    Post subject: Reply with quote
Yes, you are right.
But what makes it certain is the Q0126 S-spec code.
Simmayor
wuyuetiger
PostPosted: Sun Jun 06, 2004 10:39 am    Post subject: Reply with quote
what's the meaning of S-spec.
i'm a beginner.i didn't know much about cpu
the string is on the cpu's back, so i know Q0126
虞越
PostPosted: Mon Jun 07, 2004 12:01 am    Post subject: Reply with quote
refers to the stepping of the processor.
throughout a processors life it will go through several small revisions or steppings
