What are these 2 specs: QRV1 and QRU8
PostPosted: Mon Jul 23, 2007 10:39 pm    Post subject: What are these 2 specs: QRV1 and QRU8 Reply with quote
Both are P4-M or Celeron M, no heat spreader
probably 1.2-2.4GHz
Any ideas?
made in June of 02 (both of them)
Thanks
PostPosted: Tue Jul 24, 2007 9:08 am    Post subject: Reply with quote
QRV1: http://www.cpu-world.com/cgi-bin/IdentifyPart.pl?PART=RH80532NC025256&PROCESS=Go
QRU8: http://www.cpu-world.com/cgi-bin/IdentifyPart.pl?PART=RH80532NC029256&PROCESS=Go
PostPosted: Thu Jul 26, 2007 6:05 am    Post subject: Reply with quote
How do you arrive at those part numbers for qSpecs that are not in the database and don't have a printed part number?
PostPosted: Thu Jul 26, 2007 11:48 am    Post subject: Reply with quote
Probably because all specs arent in the db yet?
PostPosted: Thu Jul 26, 2007 12:20 pm    Post subject: Reply with quote
I thought maybe that Genna had a much more clever way of figuring it out Smile
PostPosted: Thu Jul 26, 2007 3:58 pm    Post subject: Reply with quote
I don't think it's possible to guess part number just from Q-spec. I have a different way of finding a part number if I know Q-spec number - I can look it up.
