HELP! Athlon or celeron
goffster
PostPosted: Thu Aug 09, 2007 6:12 pm    Post subject: HELP! Athlon or celeron Reply with quote
So to make a long story short, I have 2 comps and I cant decide which one is the better to use as far as the cpu gos. I used a program called cpuid and here are the results for both. Which is better?
Processor 1 (ID = 0)
Number of cores :1
Number of threads :1 (max 1)
Codename :Thunderbird
Specification :AMD Athlon(tm) processor
Package :Socket A (462)
CPUID :6.4.4
Extended CPUID :7.4
Core Stepping :A9
Technology :0.18 um
Core Speed :1329.8 MHz (10.0 x 133.0 MHz)
Rated Bus speed :266.0 MHz
Instructions sets :MMX (+), 3DNow! (+)
L1 Data cache :64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache :64 KBytes, 2-way set associative, 64-byte line size
L2 cache :256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control :no
K7 Thermal sensor :no
and the other
Number of cores :1
Codename :Northwood
Specification :Intel(R) Celeron(R) CPU 2.30GHz
Package :Socket 478 mPGA (platform ID = 2h)
CPUID :F.2.7
Extended CPUID :F.2
Brand ID :10
Core Stepping :C1
Technology :0.13 um
Core Speed :2292.1 MHz (23.0 x 99.7 MHz)
Rated Bus speed :398.6 MHz
Stock frequency :2300 MHz
Instructions sets :MMX, SSE, SSE2
L1 Data cache :8 KBytes, 4-way set associative, 64-byte line size
Trace cache :12 Kuops, 8-way set associative
L2 cache :128 KBytes, 2-way set associative, 64-byte line size
FID/VID Control :no
PostPosted: Thu Aug 09, 2007 9:44 pm    Post subject: Reply with quote
Tough one.
We need a few more things:
what are you planning to do with this PC?
gaming; mail and surfing etc.
Be extensive in answering.
I had Athlon 1400 (133 FSB) and Celeron 2.0 Northwood, depending on the app you are using, because of the 600 mhz difference, one can be better than the other. In the Whole, the 1400 was better, but like zipping and others, was slower (not that dramatically).
You have 1 ghz of difference, maybe interesting to know your plans.
Edit:
Celeron has SSE SSE2, 2.3 Ghz... uhm, I'd say it's better.
Waiting for your reply though.
Goffster
PostPosted: Thu Aug 09, 2007 10:28 pm    Post subject: Using it for Reply with quote
Thanks for the reply... Ill be using the computer for all of the things that you mentioned. Mostly gaming like half life 2 and swkotor2. Also lots of net surfing and downloading and emails. I dont do much cd burning, but I do use a playstation emulator. Other than that its just basic computer stuff. Looking forward to your reply.
PostPosted: Fri Aug 10, 2007 8:08 am    Post subject: Reply with quote
If these are the two alternatives, Celeron 2.3.
I'd suggest to buy Amd Athlon Xp, on ebay, if you are in the US you'll find good bargains for cheap.
People give your 2 cents here.
Wait for some more replies.
goffster
PostPosted: Fri Aug 10, 2007 3:17 pm    Post subject: Cant decide Reply with quote
Thanks again man, but I still cant decide for sure. I noticed that there are lots of other numbers that are higher on the athlon and I was wondering if you know what those are?
PostPosted: Fri Aug 10, 2007 3:56 pm    Post subject: Reply with quote
You may want to look not only which processor is faster, but also which board has better upgrade potential. Say, if you Intel board can be upgraded to Pentium 4 2.8 GHz, and AMD board can take Athlon XP 3200+ then you may want to go with the AMD board. My feeling, though, is that your Intel board has better potential.
goffster
PostPosted: Fri Aug 10, 2007 4:08 pm    Post subject: Boards Reply with quote
The board with the celeron is an emacines and the athlon is on a via Technologies VT8367-8235 with 4 pci slots and supports ddr ram and sd ram, separately of course. Does any one know the best processor that I can put into the via, as I think it is the nicer of the boards.
PostPosted: Fri Aug 10, 2007 7:43 pm    Post subject: Re: Boards Reply with quote
Sorry, can't help with this one
VT8367-8235 is a chipset, not a motherboard. It may support 333 MHz FSB, which means you may be able to use Athlon XP 3000+. Try to find out make and model of your Athlon motherboard either by looking at the motherboard (it should be printed somewhere in big letters), or look at what BIOS shows when you start your computer.
goffster
PostPosted: Sat Aug 11, 2007 9:54 pm    Post subject: Got it Reply with quote
My mother board is a sv266a
Sorry that took so long. any idea of the best processor I could put in it.
PostPosted: Sat Aug 11, 2007 10:09 pm    Post subject: Reply with quote
It supports Athlon XP 2400+ or maybe even Athlon XP 2600+:
http://www.cpu-world.com/forum/viewtopic.php?p=39706
It may not support Athlon XP 3000+. I think it'll be better to stay with Celeron computer.
goffster
PostPosted: Sun Aug 12, 2007 2:12 am    Post subject: max Reply with quote
Thank you for your help so far, but can any one tell me for sure the absolute best processor that I can buy for the sv266a. Smile I cant find that info any where.
PostPosted: Sun Aug 12, 2007 12:15 pm    Post subject: Reply with quote
http://64.168.125.230/support/Syntax/Motherboard/SV266A/Manual/
goffster
PostPosted: Mon Aug 13, 2007 12:56 am    Post subject: help Reply with quote
That really didnt help much, but thank you for the effort. That manual tells me the cpus that I can use that where currently available when the board was made, but I need to know the best that I can put in it now.
goffster
PostPosted: Wed Aug 15, 2007 8:20 pm    Post subject: Nope Reply with quote
No help here eh... Thats okay, ill try some where els! Thank you guys who did answer.
