the difference of 2 VIA C3-800
bluecloud
PostPosted: Thu Aug 16, 2007 3:10 am    Post subject: the difference of 2 VIA C3-800 Reply with quote
what's the difference of the 2 same VIA c3-800?
I think the upper is common.
click to find more cpus: http://stores.ebay.com/CpuPal
PostPosted: Thu Aug 16, 2007 5:57 am    Post subject: Reply with quote
Have they both got the same voltage rating? That's the biggest clue to what core is in each of them...
PostPosted: Thu Aug 16, 2007 6:49 am    Post subject: Reply with quote
I use this resource for identify the VIA CPU's
http://www.bytes-and-more.de/tech/via_c3_tech.htm
May be the first is a Samuel 2 or an Ezra core (vary the voltage) and the second an Ezra-T.
PostPosted: Thu Aug 16, 2007 11:35 am    Post subject: Reply with quote
The second one could also be a Nehemia (see http://www.ukcpu.net/Collection/Processors/VIA/C3/C3_Images/C3_133_866A_1.4V.jpg for an 866MHz example that is otherwise the same).
That is why knowing the voltage (and in some cases other markings) will always tell you more than just knowing the part number, especially for the C3 chips (note that if anyone wants to check the info on my site, I currently have the wrong thumbnail for the Nehemiah 866AMHz, and will be changing that on my next update...).
