Z8 MPU
Butzabear
PostPosted: Fri Jul 30, 2004 9:08 am    Post subject: Z8 MPU Reply with quote
Would a Z8 Z0868108PSC with a date code of 1987 work ok when used as a replacement for the same chip with a date code of 1990?
Thanks
PostPosted: Fri Jul 30, 2004 10:25 am    Post subject: Reply with quote
It should work ok as long as the part number (Z0868108PSC) is the same.
Genna
PostPosted: Fri Jul 30, 2004 1:33 pm    Post subject: Reply with quote
Yup, you'll be fine.
Timings will be the same (have to be for it to pass validation)
Butzabear
PostPosted: Fri Jul 30, 2004 1:41 pm    Post subject: Reply with quote
Thanks a lot. I've already swapped a defective 1993 D/C with the afore mentioned 1990 and there were no problems. The only availability I have at this time is 1987 D/C. Just wasn't sure.
Thanks again,
Eric
