SN74AS888/890 bit slice?
Unzlbunzl
PostPosted: Thu Oct 11, 2007 3:53 pm    Post subject: SN74AS888/890 bit slice? Reply with quote
hi! does anybody have further info on sn74as888 and sn74as890? some google hits make them look like 8-bit slice processors but nothing further.
regards
Christian
PostPosted: Fri Oct 12, 2007 6:43 am    Post subject: Reply with quote
sn74as888 is definitely a bit-slice processor. I ran out of usable time before I could get more info...
PostPosted: Fri Oct 12, 2007 9:12 am    Post subject: Reply with quote
SN54AS888/SN74AS888 is an 8-bit ALU that supports 13 arithmetic and logical operations: add, subtract, divide, multiply, absolute value, etc. Multiple AS888 units can be cascaded, i.e. it's possible to use multiple ALUs to build 8/16/24/...-bit processors. By the way, there is SN54AS887/SN74AS887 - this one is not cascadable.
SN54AS890/SN74AS890 is a 14-bit microsequencer. The chip has 64 instructions, includes stack memory and supports interrupts.
Chiefish
PostPosted: Fri Oct 12, 2007 9:14 am    Post subject: Reply with quote
Nice work Gen, how did you manage to come up with that , i googled the heck out of that p/n and couldnt find anything even close to what you just described.
PostPosted: Fri Oct 12, 2007 10:12 am    Post subject: Reply with quote
This info is from Texas Instruments "Maser Selection Guide" book.
Unzlbunzl
PostPosted: Sun Oct 14, 2007 11:16 am    Post subject: Reply with quote
Thanks for digging out that info, these seem to be quite uncommon.
