Digital Cameras
PostPosted: Thu Dec 06, 2007 6:49 pm    Post subject: Digital Cameras Reply with quote
Hey folks,
I decided to upgrade my camera and I bought a Nikon D40.
I cant find the special JAC mode I asked for. The one where you just point the camera at anything and just press the button for amazing pictures.
Awesome camera though. Smile Cheap as well!
How many people here have DSLRs?
Windmiller
PostPosted: Thu Dec 06, 2007 7:17 pm    Post subject: Reply with quote
My sister just bought the same camera and loves it!!!
I've got a Canon G4...not quite SLR.
PostPosted: Thu Dec 06, 2007 7:52 pm    Post subject: Reply with quote
Awesome. I am saving up for the Nikon 18-200mm VR lens. Costs more than the damn camera.
http://www.kenrockwell.com/nikon/18200.htm
PostPosted: Fri Dec 07, 2007 5:03 am    Post subject: Reply with quote
I have a Canon EOS 400D with Canon EFS 17-85 lens.
Not long ago I purchased a Metz 58AF-1 flash and an additional lens (Tamron 28-300 VC)
The price of original DSLR accessories is quite high. You should look at lenses from third party manufacturers. Smile
The Nikon 18-200mm VR costs about EUR 700.
A similar lens from Tamron AF 28-300mm F/3,5-6,3 XR Di VC LD Aspherical IF MACRO costs about EUR 500.
http://www.tamron.de/index.php?id=417&L=2&kc_prid=601&kc_prgrid=7
I purchased such a lens (Canon version) for EUR 530. I am very satisfied with it.
There is also a Nikon version.
The Tamron 28-300 VC has also an image stabiliser.
There is only one significant difference between both lenses - the Nikon is an AF-S lens and the Tamron an AF one.
AF-S lenses smaller and can be only used with half-size-sensor DSLRs like your D40.
A full size lens (AF) will fit in your half-size-sensor DSLR, in the film SLR and in the full-size-sensor DSLR you will buy later Wink
PostPosted: Fri Dec 07, 2007 5:18 am    Post subject: Reply with quote
Good old EOS 20D for me
+ Canon 20-35, Canon 28-135 and Canon 300/4 IS L
soeren
PostPosted: Fri Dec 07, 2007 7:44 am    Post subject: camera Reply with quote
I've got a nice Samsung S85
PostPosted: Fri Dec 07, 2007 1:49 pm    Post subject: Reply with quote
Thanks Qwerty. Will I miss the 18mm?
PostPosted: Fri Dec 07, 2007 5:40 pm    Post subject: Reply with quote
I don't know. Wink
That depends on you. What kind of pictures are you going to take with the lens?
A wide-angle lens is useful when taking pictures of large objects from a close distance (ex. indoor photography).
Unfortunately the wide-angle lenses produce pictures with considerable perspective distortion.
You should always use a medium zoom setting (25-35mm) and take pictures from longer distance if possible.
An example (taken from www .sportsphotoguy.com)
Another purpose of a wide-angle lens is photo art.
In this case you need a professional lens (ex. Nikkor AF-S DX 4,0/12 - 24mm) for only EUR 1049.00 Smile
