forums
skold
PostPosted: Fri Oct 01, 2004 9:16 am    Post subject: forums Reply with quote
did you upgrade the hardware as well, or is the new version of phpbb just a lot faster? it seems really speedy now
PostPosted: Fri Oct 01, 2004 12:01 pm    Post subject: Re: forums Reply with quote
I don't have control over hardware, I can only change software. I installed "eXtreme styles" modification (http://www.phpbb.com/phpBB/viewtopic.php?t=125251). Normally, when a forum page is requested, the phpBB loads a few template files, generates PHP code from them and then executes the code. The eXtreme style mod caches generated code, and instead of generating the code next time, it loads cached copy. It should be faster than plain phpBB forum, but I don't know how much faster.
Genna
skold
PostPosted: Fri Oct 01, 2004 8:08 pm    Post subject: Reply with quote
well its very nice Smile im working on converting my site to smarty templates, and im hoping it speeds it up a lot ..
