Sten
Joined: 04 Feb 2006 Posts: 358 Location: Czech Republic
Posted: Tue Jan 22, 2008 2:29 pm Post subject: IBM 6x86L P120+ |
| It is finally in my collection. I never saw this model. Feel free to ad it into Cpu-db |
Heartbreak one
Joined: 19 Dec 2007 Posts: 130 Location: Mandal, Norway
Posted: Tue Jan 22, 2008 2:35 pm Post subject: |
That is a nice looking chip! It is in perfect condition to. Congratulation  _________________ "640 cores should be enough for anybody" - evermore xD |
Posted: Tue Jan 22, 2008 5:12 pm Post subject: |
I'd not come across that one before. Nice find!
Do you have a motherboard it can be tested on? I'd be interested to know CPUID and the DIRs (Cyrix Device ID Registers) say... _________________ My graphics card database can be found at http://www.gpuzoo.com.
el_gecko
Joined: 25 May 2005 Posts: 1553 Location: Nice, France
Posted: Wed Jan 23, 2008 5:50 am Post subject: |
Like this one?  _________________ My microprocessor collection: The Gecko's CPU Library |
Windmiller
Joined: 24 Jun 2005 Posts: 1716 Location: Chapel Hill, NC
Posted: Wed Jan 23, 2008 9:05 am Post subject: |
Very nice  |
Posted: Wed Jan 23, 2008 12:53 pm Post subject: |
Does anyone know if this was only released with core revision B? _________________ My graphics card database can be found at http://www.gpuzoo.com.
Sten
Posted: Wed Jan 23, 2008 2:26 pm Post subject: |
Hi debs3759
I will test it during this weekend
P.S. Do you know program to test this DIRs (Cyrix Device ID Registers) ? |
Posted: Wed Jan 23, 2008 4:44 pm Post subject: |
| Sten wrote: | Hi debs3759
The CPUID code at my site will run on a command prompt and give you the values in the DIRs. In it's current (almost dormant - I recently started working on the code again) state, it will tell you it has used Cyrix DIRs to detect what processor it is, and the CPUID value will constitute DIR0:DIR1, each being two Hex characters.
The code can be found at http://www.ukcpu.net/Programming/OS/index.asp, in the file CPUID.ZIP. Source code is included, if you are interested in that. Te file CPUID.COM needs to be run full screen, at a DOS prompt (eg a command prompt run full screen).
I aim to improve both the code and the interface at some point, but for now am working more on updating the list of processor families that are supported
I just checked, and the app doesn't close itself after running, so you can double click on it from a windows folder, then make the window full screen to be able to read the text. You can then close the window after to close the app. _________________ My graphics card database can be found at http://www.gpuzoo.com.
Unzlbunzl
Joined: 30 Jan 2007 Posts: 468 Location: Graz, Austria
Posted: Wed Jan 23, 2008 4:57 pm Post subject: |
| Quote: | | I just checked, and the app doesn't close itself after running |
wondered about this when using it with native dos - had to reboot a lot of times - used it a lot of times - nice tool debs! |
Posted: Wed Jan 23, 2008 5:19 pm Post subject: |
That's one of the things I forgot hadn't been done when I let it go dormant, so will be getting fixed (I'll have it wait for a keypress before shutting down, so it can still be double-clicked in a DOS box
I hope to have an update online before the summer (it's so long since I did some proper programming, I'm not going to set my expectations too high immediately ), but may manage to get some intermediary updates online before then.. _________________ My graphics card database can be found at http://www.gpuzoo.com.
Sten
Posted: Sun Jan 27, 2008 8:24 am Post subject: |
Hi debs3759,
Unfortunatelly your application always stopped when identifying, but I have 2 infos:
Stepping: 4
Do you know some good cpu testing application for Win98 SE ?
Thanks
Best Rgrds
Sten |
Posted: Sun Jan 27, 2008 9:45 am Post subject: |
3122 (that's DIR0 = 31, DIR1 = 22) makes it revision 4.2, which is the same as all 6x86L I have seen info on (and fortunately ties in with the revision shown in the part number). Thanks for testing it, I'd not seen enough of them to have confidence about putting the part number on my web site
For testing with a Windows interface, I think most people use cpu-z (which looks to me like a very good application - the only reason I don't use it is because I don't need the extended info.
I will be improving the interface on my code, part of which will involve making it look more attractive (as thatmatters to some users more than how an app looks), as well as adding the ability to close the app down properly (a feature that was only missed out because my original intention was to integrate it into the start-up code of the OS I started work on...) _________________ My graphics card database can be found at http://www.gpuzoo.com.
