| AMD Phenom : which generation according to you ? |
| 7 |
12% |
[ 2 ] |
| 8 |
25% |
[ 4 ] |
| 9 |
37% |
[ 6 ] |
| 10 |
6% |
[ 1 ] |
| Don't care about it |
18% |
[ 3 ] |
| Total Votes : 16 |
Posted: Sun Mar 02, 2008 10:03 am Post subject: AMD Phenom : which generation according to you ? |
| I'm planning to enter AMD Phenoms in my cpu database but, I have a problem to order it. Would it be a 9th generation cpu, or only a 8th (like Core 2 & Athlon 64) |
Chiefish
Posted: Sun Mar 02, 2008 10:38 am Post subject: |
I think they are considered K10, but im not positive  |
Posted: Sun Mar 02, 2008 10:41 am Post subject: |
They are 9th generation, and yes they are the K10 family  _________________ My graphics card database can be found at http://www.gpuzoo.com.
andamus
Posted: Sun Mar 02, 2008 12:55 pm Post subject: |
for me they are 8th generation. they core it's "only" an enhanced Athlon 64 core without any architectural modification. Like the switch between P4 Willamete to P4 Nothwood (without HT)only "few" upgrade (L2 cache size, bus freq, etc) while the step from Nortwood to Prescot was greater in terms of architecure (pipelines goes from 20 stages to 31, 64bit core, etc etc) |
thomsonicus
Posted: Sun Mar 02, 2008 1:10 pm Post subject: |
I agree with andamus - nothing really major has changed so there's no need to consider it another generation _________________ Power without the price. |
Posted: Sun Mar 02, 2008 1:12 pm Post subject: |
Space for plenty of innovation...
Commercially they are as Debs outlined, K10 9th generation (if they just didn't change much from K8 that's their bet ) |
